Salvage old brewblox data
Today, for whatever reasons, my Raspberry Pi quit on me.
I use it to run both openhab (for home automation) and brewblox.
Weirdly enough, openhab still works, but brewblox refuses to start (traefik says the interface is already in use and I get all kinds of weird errors and crashes). I assume the SD card is broken again (even though I tried to limit SD card wear as much as possible).
Of course I didn’t backup my brewblox settings. Is there any way to salvage my dashboard and settings?
Unfortunately I can’t get the old brewblox installation running enough to use the brewblox-ctl backup.
I will also accept “thou shouldst perform regular backups” as an answer and will then go live with my shame quietly.
Can you run brewblox-ctl log? Depending on the error, it may be something that can just be fixed, and does not require a reinstall from backup.
Creating a backup is a good idea anyway.
Depending on when you last updated, brewblox-ctl snapshot save may be available. This does not require your services to be running (it zips your entire directory).
You can also manually zip your brewblox dir. Depending on your version, it may require some additional steps to get it working again with a new install.
In your root directory, run:
sudo tar -czf brewblox.tar.gz brewblox
Thank you for the extremely quick reply, Bob! :slight_smile:
I managed to run brewblox-ctl log:
https://termbin.com/a21k
(To rund brewblox-ctl I need to manually add the ~/.local/bin directory to the $PATH every time, even though it’s specified in .profice and .bashrc, and there’s a lot of other weird behaviour from the pi. Got random ZRAM errors (which I now disabled) and more…)
brewblox-ctl snapshot save also worked, I now have a 65MB big backup file. Can I treat that like a “normal” backup?
I’ve already installed brewblox from scratch on another Pi (which I use for experimenting) and fortunately, my fermentation fridge is still behaving nicely. The spark with all the blocks is still there and running.
Logs indicate services are currently offline, could you start then, and then re-run the log command?
If your Pi is all-round behaving weirdly, it does often indicate that another SD card died. I haven’t yet seen it throw PATH errors though - typically it slows down, and starts throwing low-level OS errors.
Snapshots can be loaded using either brewblox-ctl snapshot load, or brewblox-ctl install --snapshot FILE. They’re different from backups in that backups only include settings, and are more specific in what they save. Snapshots just zip the entire dir, history and all. Loading a snapshot will overwrite the entire brewblox dir.
brewblox-ctl up led to the following output:
[20:10:29] pi@brewpi:~/brewblox$ brewblox-ctl up
Starting brewblox_redis_1 …
Starting brewblox_spark-one_1 …
Starting brewblox_eventbus_1 …
Starting brewblox_ui_1 …
Starting brewblox_influx_1 …
Starting brewblox_redis_1 … done
Starting brewblox_spark-one_1 … done
Starting brewblox_eventbus_1 … done
Starting brewblox_ui_1 … done
Starting brewblox_influx_1 … done
Starting brewblox_history_1 … done
d340b): Bind for 0.0.0.0:443 failed: port is already allocated
ERROR: for traefik Cannot start service traefik: driver failed programming external connec
y on endpoint brewblox_traefik_1 (10330d14f76b330f33ad4aa17947be57c452f3b2f32521fe08a4ed9ca
Command ‘docker-compose up -d --remove-orphans’ returned non-zero exit status 1.
What I see is that traefik seems to be started twice… That’s weird.
The new log is here:
https://termbin.com/m9av
I’ll try using the snapshot later when I have access to the other Pi again.
New SD card is already ordered and I’ll try to hook up a HDD to the Pi this time. :slight_smile:
It’s telling you that something already is using port 443. Maybe your Home Assistant?
To check, you can run
sudo netstat -tulpn
I managed to use the snapshot to restore my data.
Thanks so much, Bob! :slight_smile: This saved my day.
For curiosities sake: When using brewblox-ctl update to try to fix my installation, the following happens:
INFO Starting services…
Creating brewblox_eventbus_1 …
Creating brewblox_history_1 …
Creating brewblox_ui_1 …
Creating brewblox_redis_1 …
Creating brewblox_influx_1 …
Creating brewblox_spark-one_1 …
Creating brewblox_traefik_1 …
Creating brewblox_traefik_1 … error
ERROR: for brewblox_traefik_1 Cannot start service traefik: driver failed programming external connectivity on endpoint brewblox_traefik_1 (5b4c6aeaa1e03d8c06008264b3e93c49153add9fec83e8075060e77a7a2d5518): Bind for 0.0.0.0:443 failed: port is already allocated
Here’s the point where traefik_1 is apparently started twice and the second one reports an error…
And this is also weird:
WARNING: The requested image’s platform (linux/amd64) does not match the detected host platform (linux/arm/v7) and no specific platform was requested
6bf50d01f92343d2b1ea9791ffdacd94df73bb457fce2574e3f4398e3f45426a
Probably something to do with messed up environment variables?
But I’ve got a running Brewblox installation with my setup again. So all else is just, as I said - curiosity. :slight_smile:
Good to hear it works again!
You can ignore the platform warning for ctl-lib. It’s technically correct, but we only use the container to copy python files, so it never becomes an issue.
The error during the update is the same again: something else is using port 443 already. It’s the default port for HTTPS, so it’s probably some webserver on your Pi.
Well weirdly enough, only “docker-proxy” is shown running on 443 with sudo netstat -tulpn…
This can happen if Docker failed to clean up some earlier containers and their claims.
A fix would be to run brewblox-ctl kill (this will stop and clean up all containers), and then reboot.
After reboot, netstat should no longer show a process being attached to 443.
I am having the same issue again with a freshly installed Raspi. Apparently there is some conflict between openHab and Brewblox. I installed openHab3 first and after that proceeded to install Brewblox.
(I don’t want to use two different Raspis for two programs.)
First issue I encountered again is that brewblox-ctl is missing from the PATH. I found out why:
openhab uses .bashrc-profile while brewblox is writing to .profile, which is apparently ignored when a .bashrc_profile exists. I don’t know in which conditions one would use which file, but maybe the brewblox installer could check which file is being used and then writing the path to the corresponding file (could imagine that might be an issue for more people).
That was fixed easily enough (just deleted the .bashrc_profile, there wasn’t much useful stuff in there).
Brewblox installed just fine, but when running brewblox-ctl up, it hangs at the following point:
INFO Starting configured services…
Creating brewblox_traefik_1 … done
Creating brewblox_history_1 … done
Creating brewblox_influx_1 … done
INFO Configuring history settings…
Connecting https://localhost:443/history/history/ping, attempt 1/60
Connecting https://localhost:443/history/history/ping, attempt 2/60
Success!
INFO Stopping services…
Stopping brewblox_history_1 … done
Stopping brewblox_influx_1 … done
Stopping brewblox_traefik_1 … done
INFO All done!
pi@ANNIE:~/brewblox $ brewblox-ctl up
Creating brewblox_ui_1 … done
Creating brewblox_spark-one_1 … done
ERROR: for brewblox_eventbus_1 UnixHTTPConnectionPool(host=‘localhost’, port=None): Read timed out. (read timeout=60)
ERROR: for brewblox_influx_1 UnixHTTPConnectionPool(host=‘localhost’, port=None): Read timed out. (read timeout=60)
ERROR: for brewblox_history_1 UnixHTTPConnectionPool(host=‘localhost’, port=None): Read timed out. (read timeout=60)
ERROR: for brewblox_redis_1 UnixHTTPConnectionPool(host=‘localhost’, port=None): Read timed out. (read timeout=60)
ERROR: for eventbus UnixHTTPConnectionPool(host=‘localhost’, port=None): Read timed out. (read timeout=60)
…and it crashed the entire pi. I can’t reach it via network anymore (SSH, web, anything).
I’ll try to find more information about this. Rebooted the pi now, here’s the brewblox-log:
https://termbin.com/ungox
Second very weird thing: On my other Pi, where I thought the SD card was corrupted, for some strange reason brewblox is running again. Flawlessly. Last thing I did was a brewblox-ctl kill and then I left it alone. Yesterday I noticed that brewblox was running again neatly. SD card seems to be fine as well.
Update: Hard-rebooting (unplugging) the Pi solved the problem and Brewblox is now running.
But this looked too much like some of the issues I had before so I fear there might be something lurking deep inside the code…
Well-behaved .bash_profile implementations should load .profile as well. As usual, stack overflow explains this in more depth.
We can check anyway, but we’ll probably have to limit ourselves to a warning if .bash_profile exists, but has not loaded .profile. We try and keep our changes to the host system to an absolute minimum. The $HOME/.local/bin directory where brewblox-ctl lives is added to PATH by default in Debian Buster. It was considered a bug that Debian Stretch didn’t do this.
These Docker timeout errors can be caused by a variety of reasons.
The primary suspect is that OpenHAB + Brewblox causes memory issues.
Have you disabled swap memory?
If you open htop, what is idle / active memory usage with OpenHAB and Brewblox both running?
Thanks for pointing that out. I created a github issue for openhab stating very politely that their setup should include the .profile. :slight_smile:
I have disabled swap memory now. I think I had done that on my old machine as well, but I’m not sure anymore.
htop is showing 500MB of memory usage, on my old Pi even 750MB (which is currently running both openhab and brewblox in a production environment). Maybe I should invest in a Pi4 with more RAM? Or just run both systems on two different Pis after all?
I’d love to run all of it on my NAS, but back then I managed to buy one of the only systems that runs on powerPC… and almost nothing compiles on a PPC…
I’d keep an eye on memory usage. Scaling up hardware would be a solution if you’re commonly maxed out.
We support the Pi because it’s a cheap way to get a dedicated server, but Brewblox typically uses ~400MB memory. That is a significant chunk of the Pi3’s 1GB RAM.
You’re correct on this count. We’re already waiting for upstream support for ARM64. PPC is comparatively obscure.
Reviving this old topic. Fooled around with my raspberry a bit and had to do a couple of ungraceful restarts (read: pulling the plug).
I encountered something similar and the problem seemed to be that the eventbus-container was being created twice (and thus complaining that the port was already in use). Same problem occurred above, online with traefik, it’s actually in the log I posted above:
Had the same now with eventbus. I deleted all docker images I could find, ran brewblox-ctl kill a couple of times and rebooted. Then stopped all other software and restarted brewblox. Then it worked.
But apparently, when crashing or unplugging the pi, there might be some leftover double containers? I have no idea why that might be happening, but maybe it gives you a lead (if this is something that needs solving).
Thanks for taking the effort to provide extra info!
We haven’t looked into the exact cause beyond “hard crashes can cause undefined state”. The chain of events is clear enough, but it’s not an issue in our code or something we can work around.
Deleting images is slightly overkill: they are the executable data, and will not be changed at runtime.
What would be the best way to solve the “double services / containers” problem? Should brewblox-ctl kill and a reboot be sufficient?
Another observation: Using ZRAM swapping also seems to cause trouble.
Kill and reboot should indeed be sufficient.
Best I can tell, on crash either the port claim persisted, or the restart: unless_stopped configuration flag starts a malfunctioning image which claims the port.
Either way, there’s a leftover process with a claim. If the process doesn’t unclaim the resource, the OS will do so about ~1m after process death. A reboot will also wipe current claims.
It’s not actually trying to start the service twice: the two lines in the log should be interpreted as “starting container”, and “failed to start container”.
The best way to deal with the problem is to prevent hard crashes.
Thanks Bob!
Yes, I’m working on that. I will give Brewblox it’s own dedicated Pi at some point (when I’m done tinkering). :slight_smile:
