Help! Was working but cannot get script running now. So frustrated!
We’ll not be able to help you if you don’t provide more info.
What is in the log files, which you can find under the maintenance panel?
Are you running the latest docker release?
Mar 24 2018 15:56:59 Notification: Script started for beer ‘My First BrewPi Run’
Mar 24 2018 15:56:59 Connecting to controller…
Mar 24 2018 15:56:59 Background thread for serial started
Mar 24 2018 15:57:09 Warning: Cannot receive version number from controller. Check your port setting in the Maintenance Panel or in settings/config.cfg.
Mar 24 2018 15:59:56 Notification: Script started for beer ‘My First BrewPi Run’
Mar 24 2018 15:59:56 Connecting to controller…
Mar 24 2018 15:59:56 Background thread for serial started
Mar 24 2018 15:59:56 Serial (re)connected at port: /dev/ttyACM0
Mar 24 2018 15:59:58 Found BrewPi v0.5.4 build 0.5.4-0-gb18a0ebdf, running on a Particle p1 with a V3 shield
Mar 24 2018 16:04:18 Installed devices received: []
Mar 24 2018 16:04:18 Available devices received: [{“a”: “288A76FE0800008B”, “c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 2, “j”: 0.0, “p”: 0, “t”: 0}, {“a”: “28FE69D509000093”, “c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 2, “j”: 0.0, “p”: 0, “t”: 0}, {“a”: “2801A702090000C2”, “c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 2, “j”: 0.0, “p”: 0, “t”: 0}, {“c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 1, “p”: 25, “t”: 0, “x”: 0}, {“c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 1, “p”: 24, “t”: 0, “x”: 0}, {“c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 1, “p”: 4, “t”: 0, “x”: 0}, {“c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 1, “p”: 29, “t”: 0, “x”: 0}, {“c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 1, “p”: 28, “t”: 0, “x”: 0}]
Mar 24 2018 16:04:42 Installed devices received: []
Mar 24 2018 16:04:42 Available devices received: [{“a”: “288A76FE0800008B”, “c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 2, “j”: 0.0, “p”: 0, “t”: 0}, {“a”: “28FE69D509000093”, “c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 2, “j”: 0.0, “p”: 0, “t”: 0}, {“a”: “2801A702090000C2”, “c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 2, “j”: 0.0, “p”: 0, “t”: 0}, {“c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 1, “p”: 25, “t”: 0, “x”: 0}, {“c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 1, “p”: 24, “t”: 0, “x”: 0}, {“c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 1, “p”: 4, “t”: 0, “x”: 0}, {“c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 1, “p”: 29, “t”: 0, “x”: 0}, {“c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 1, “p”: 28, “t”: 0, “x”: 0}]
Mar 24 2018 16:05:13 Installed devices received: []
Mar 24 2018 16:05:14 Available devices received: [{“a”: “288A76FE0800008B”, “c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 2, “j”: 0.0, “p”: 0, “t”: 0, “v”: 21.75}, {“a”: “28FE69D509000093”, “c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 2, “j”: 0.0, “p”: 0, “t”: 0, “v”: 18.875}, {“a”: “2801A702090000C2”, “c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 2, “j”: 0.0, “p”: 0, “t”: 0, “v”: 19.375}, {“c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 1, “p”: 25, “t”: 0, “x”: 0}, {“c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 1, “p”: 24, “t”: 0, “x”: 0}, {“c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 1, “p”: 4, “t”: 0, “x”: 0}, {“c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 1, “p”: 29, “t”: 0, “x”: 0}, {“c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 1, “p”: 28, “t”: 0, “x”: 0}]
Mar 24 2018 16:14:06 Installed devices received: []
Mar 24 2018 16:14:07 Available devices received: [{“a”: “288A76FE0800008B”, “c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 2, “j”: 0.0, “p”: 0, “t”: 0, “v”: 21.75}, {“a”: “28FE69D509000093”, “c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 2, “j”: 0.0, “p”: 0, “t”: 0, “v”: 19.0}, {“a”: “2801A702090000C2”, “c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 2, “j”: 0.0, “p”: 0, “t”: 0, “v”: 19.5}, {“c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 1, “p”: 25, “t”: 0, “x”: 0}, {“c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 1, “p”: 24, “t”: 0, “x”: 0}, {“c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 1, “p”: 4, “t”: 0, “x”: 0}, {“c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 1, “p”: 29, “t”: 0, “x”: 0}, {“c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 1, “p”: 28, “t”: 0, “x”: 0}]
Mar 24 2018 16:14:27 Installed devices received: []
Mar 24 2018 16:14:27 Available devices received: [{“a”: “288A76FE0800008B”, “c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 2, “j”: 0.0, “p”: 0, “t”: 0, “v”: 21.75}, {“a”: “28FE69D509000093”, “c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 2, “j”: 0.0, “p”: 0, “t”: 0, “v”: 19.0}, {“a”: “2801A702090000C2”, “c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 2, “j”: 0.0, “p”: 0, “t”: 0, “v”: 19.5}, {“c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 1, “p”: 25, “t”: 0, “x”: 0}, {“c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 1, “p”: 24, “t”: 0, “x”: 0}, {“c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 1, “p”: 4, “t”: 0, “x”: 0}, {“c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 1, “p”: 29, “t”: 0, “x”: 0}, {“c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 1, “p”: 28, “t”: 0, “x”: 0}]
Mar 24 2018 16:14:56 Serial Error: [Errno 5] Input/output error)
Mar 24 2018 16:16:25 Serial (re)connected at port: /dev/ttyACM0
Mar 24 2018 16:16:27 Serial Error: [Errno 5] Input/output error)
Mar 24 2018 16:16:32 Serial (re)connected at port: /dev/ttyACM0
Mar 24 2018 16:16:36 Serial Error: [Errno 5] Input/output error)
Mar 24 2018 16:16:47 Serial (re)connected at port: /dev/ttyACM0
Mar 24 2018 16:16:54 Serial Error: [Errno 5] Input/output error)
Mar 24 2018 16:17:00 Serial (re)connected at port: /dev/ttyACM0
Mar 24 2018 16:17:09 Serial Error: [Errno 5] Input/output error)
Mar 24 2018 16:17:28 Serial (re)connected at port: /dev/ttyACM0
Mar 24 2018 16:17:29 Controller debug message: WARNING 2: Temperature sensor disconnected pin 0, address 28FE69D509000093
Mar 24 2018 16:17:30 Controller debug message: WARNING 2: Temperature sensor disconnected pin 0, address 2801A702090000C2
Mar 24 2018 16:17:57 Serial Error: [Errno 5] Input/output error)
Mar 24 2018 16:18:04 Serial (re)connected at port: /dev/ttyACM0
Mar 24 2018 16:18:25 Serial Error: [Errno 5] Input/output error)
Mar 24 2018 16:18:27 Serial (re)connected at port: /dev/ttyACM0
Mar 24 2018 16:18:58 Serial Error: [Errno 5] Input/output error)
Mar 24 2018 16:19:00 Serial (re)connected at port: /dev/ttyACM0
Mar 24 2018 16:20:19 Device updated to: {“i”:2,“t”:1,“c”:1,“b”:1,“f”:9,“h”:2,“d”:0,“p”:0,“a”:“2801A702090000C2”,“j”: 0.000}
Mar 24 2018 16:20:21 Device updated to: {“i”:1,“t”:1,“c”:1,“b”:0,“f”:5,“h”:2,“d”:0,“p”:0,“a”:“28FE69D509000093”,“j”: 0.000}
Mar 24 2018 16:20:21 Controller debug message: WARNING 4: Falling back on backup sensor.
Mar 24 2018 16:20:21 Controller debug message: INFO MESSAGE 21: Back on main sensor instead of backup sensor.
Mar 24 2018 16:20:24 Device updated to: {“i”:3,“t”:1,“c”:1,“b”:0,“f”:6,“h”:2,“d”:0,“p”:0,“a”:“288A76FE0800008B”,“j”: 0.000}
Mar 24 2018 16:22:01 Device updated to: {“i”:3,“t”:3,“c”:1,“b”:0,“f”:3,“h”:1,“d”:0,“p”:4,“x”:0}
Mar 24 2018 16:22:15 Device updated to: {“i”:4,“t”:3,“c”:1,“b”:0,“f”:2,“h”:1,“d”:0,“p”:29,“x”:0}
Mar 24 2018 16:25:58 Notification: Restarted logging for beer ‘Test’.
Mar 24 2018 16:27:38 Controller debug message: INFO MESSAGE 12: Received new setting: tempFormat = F
Mar 24 2018 16:28:16 Controller debug message: INFO MESSAGE 12: Received new setting: mode = t
Mar 24 2018 16:29:53 Notification: Fridge temperature set to 19.8 degrees in web interface
Mar 24 2018 16:29:53 Controller debug message: INFO MESSAGE 12: Received new setting: mode = f
Mar 24 2018 16:29:53 Controller debug message: INFO MESSAGE 12: Received new setting: fridgeSet = 19.8
Mar 24 2018 16:32:30 Notification: Fridge temperature set to 60.0 degrees in web interface
Mar 24 2018 16:32:31 Controller debug message: INFO MESSAGE 12: Received new setting: mode = f
Mar 24 2018 16:32:31 Controller debug message: INFO MESSAGE 12: Received new setting: fridgeSet = 60.0
Mar 24 2018 16:36:13 Installed devices received: [{“a”: “28FE69D509000093”, “c”: 1, “b”: 0, “d”: 0, “f”: 5, “i”: 1, “h”: 2, “j”: 0.0, “p”: 0, “t”: 1}, {“a”: “2801A702090000C2”, “c”: 1, “b”: 1, “d”: 0, “f”: 9, “i”: 2, “h”: 2, “j”: 0.0, “p”: 0, “t”: 1}, {“c”: 1, “b”: 0, “d”: 0, “f”: 3, “i”: 3, “h”: 1, “p”: 4, “t”: 3, “x”: 0}, {“c”: 1, “b”: 0, “d”: 0, “f”: 2, “i”: 4, “h”: 1, “p”: 29, “t”: 3, “x”: 0}]
Mar 24 2018 16:36:13 Available devices received: [{“a”: “288A76FE0800008B”, “c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 2, “j”: 0.0, “p”: 0, “t”: 0}, {“c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 1, “p”: 25, “t”: 0, “x”: 0}, {“c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 1, “p”: 24, “t”: 0, “x”: 0}, {“c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 1, “p”: 28, “t”: 0, “x”: 0}]
Mar 24 2018 16:36:54 Installed devices received: [{“c”: 1, “b”: 0, “d”: 0, “f”: 3, “i”: 3, “h”: 1, “p”: 4, “t”: 3, “x”: 0}]
Mar 24 2018 16:36:59 Device updated to: {“i”:3,“t”:3,“c”:1,“b”:0,“f”:3,“h”:1,“d”:0,“p”:4,“x”:0}
Mar 24 2018 16:37:08 Device updated to: {“i”:3,“t”:3,“c”:1,“b”:0,“f”:3,“h”:1,“d”:0,“p”:4,“x”:1}
Mar 24 2018 16:37:35 Installed devices received: [{“c”: 1, “b”: 0, “d”: 0, “f”: 3, “i”: 3, “h”: 1, “p”: 4, “t”: 3, “x”: 1}]
Mar 24 2018 16:38:11 Installed devices received: [{“a”: “28FE69D509000093”, “c”: 1, “b”: 0, “d”: 0, “f”: 5, “i”: 1, “h”: 2, “j”: 0.0, “p”: 0, “t”: 1, “v”: 71.375}, {“a”: “2801A702090000C2”, “c”: 1, “b”: 1, “d”: 0, “f”: 9, “i”: 2, “h”: 2, “j”: 0.0, “p”: 0, “t”: 1, “v”: 71.262}, {“c”: 1, “b”: 0, “d”: 0, “f”: 3, “i”: 3, “h”: 1, “p”: 4, “t”: 3, “v”: 0, “x”: 1}, {“c”: 1, “b”: 0, “d”: 0, “f”: 2, “i”: 4, “h”: 1, “p”: 29, “t”: 3, “v”: 0, “x”: 0}]
Mar 24 2018 16:38:12 Available devices received: [{“a”: “288A76FE0800008B”, “c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 2, “j”: 0.0, “p”: 0, “t”: 0, “v”: 72.273}, {“c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 1, “p”: 25, “t”: 0, “x”: 0}, {“c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 1, “p”: 24, “t”: 0, “x”: 0}, {“c”: 1, “b”: 0, “d”: 0, “f”: 0, “i”: -1, “h”: 1, “p”: 28, “t”: 0, “x”: 0}]
Mar 24 2018 16:39:01 stopScript message received on socket. Stopping script and writing dontrunfile to prevent automatic restart
Mar 24 2018 16:39:01 Background thread for serial stopped
stdout:
Mar 24 2018 15:59:59 {“BeerTemp”:null,“BeerSet”:null,“BeerAnn”:null,“FridgeTemp”:null,“FridgeSet”:null,“FridgeAnn”:null,“Log1Temp”:null,“Log2Temp”:null,“Log3Temp”:null,“State”:0}
Mar 24 2018 16:03:20 {“BeerTemp”:null,“BeerSet”:null,“BeerAnn”:null,“FridgeTemp”:null,“FridgeSet”:null,“FridgeAnn”:null,“Log1Temp”:null,“Log2Temp”:null,“Log3Temp”:null,“State”:0}
Mar 24 2018 16:04:22 {“BeerTemp”:null,“BeerSet”:null,“BeerAnn”:null,“FridgeTemp”:null,“FridgeSet”:null,“FridgeAnn”:null,“Log1Temp”:null,“Log2Temp”:null,“Log3Temp”:null,“State”:0}
Mar 24 2018 16:05:23 {“BeerTemp”:null,“BeerSet”:null,“BeerAnn”:null,“FridgeTemp”:null,“FridgeSet”:null,“FridgeAnn”:null,“Log1Temp”:null,“Log2Temp”:null,“Log3Temp”:null,“State”:0}
Mar 24 2018 16:06:24 {“BeerTemp”:null,“BeerSet”:null,“BeerAnn”:null,“FridgeTemp”:null,“FridgeSet”:null,“FridgeAnn”:null,“Log1Temp”:null,“Log2Temp”:null,“Log3Temp”:null,“State”:0}
Mar 24 2018 16:07:24 {“BeerTemp”:null,“BeerSet”:null,“BeerAnn”:null,“FridgeTemp”:null,“FridgeSet”:null,“FridgeAnn”:null,“Log1Temp”:null,“Log2Temp”:null,“Log3Temp”:null,“State”:0}
Mar 24 2018 16:08:25 {“BeerTemp”:null,“BeerSet”:null,“BeerAnn”:null,“FridgeTemp”:null,“FridgeSet”:null,“FridgeAnn”:null,“Log1Temp”:null,“Log2Temp”:null,“Log3Temp”:null,“State”:0}
Mar 24 2018 16:09:25 {“BeerTemp”:null,“BeerSet”:null,“BeerAnn”:null,“FridgeTemp”:null,“FridgeSet”:null,“FridgeAnn”:null,“Log1Temp”:null,“Log2Temp”:null,“Log3Temp”:null,“State”:0}
Mar 24 2018 16:10:26 {“BeerTemp”:null,“BeerSet”:null,“BeerAnn”:null,“FridgeTemp”:null,“FridgeSet”:null,“FridgeAnn”:null,“Log1Temp”:null,“Log2Temp”:null,“Log3Temp”:null,“State”:0}
Mar 24 2018 16:11:27 {“BeerTemp”:null,“BeerSet”:null,“BeerAnn”:null,“FridgeTemp”:null,“FridgeSet”:null,“FridgeAnn”:null,“Log1Temp”:null,“Log2Temp”:null,“Log3Temp”:null,“State”:0}
Mar 24 2018 16:12:27 {“BeerTemp”:null,“BeerSet”:null,“BeerAnn”:null,“FridgeTemp”:null,“FridgeSet”:null,“FridgeAnn”:null,“Log1Temp”:null,“Log2Temp”:null,“Log3Temp”:null,“State”:0}
Mar 24 2018 16:13:27 {“BeerTemp”:null,“BeerSet”:null,“BeerAnn”:null,“FridgeTemp”:null,“FridgeSet”:null,“FridgeAnn”:null,“Log1Temp”:null,“Log2Temp”:null,“Log3Temp”:null,“State”:0}
Mar 24 2018 16:14:29 {“BeerTemp”:null,“BeerSet”:null,“BeerAnn”:null,“FridgeTemp”:null,“FridgeSet”:null,“FridgeAnn”:null,“Log1Temp”:null,“Log2Temp”:null,“Log3Temp”:null,“State”:0}
Mar 24 2018 16:16:36 {“BeerTemp”:null,“BeerSet”:null,“BeerAnn”:null,“FridgeTemp”:null,“FridgeSet”:null,“FridgeAnn”:null,“Log1Temp”:null,“Log2Temp”:null,“Log3Temp”:null,“State”:0}
Mar 24 2018 16:17:39 {“BeerTemp”:null,“BeerSet”:null,“BeerAnn”:null,“FridgeTemp”:null,“FridgeSet”:null,“FridgeAnn”:null,“Log1Temp”:null,“Log2Temp”:null,“Log3Temp”:null,“State”:0}
Mar 24 2018 16:18:40 {“BeerTemp”:null,“BeerSet”:null,“BeerAnn”:null,“FridgeTemp”:null,“FridgeSet”:null,“FridgeAnn”:null,“Log1Temp”:null,“Log2Temp”:null,“Log3Temp”:null,“State”:0}
Mar 24 2018 16:19:41 {“BeerTemp”:null,“BeerSet”:null,“BeerAnn”:null,“FridgeTemp”:null,“FridgeSet”:null,“FridgeAnn”:null,“Log1Temp”:null,“Log2Temp”:null,“Log3Temp”:null,“State”:0}
Mar 24 2018 16:20:43 {“BeerTemp”:19.63,“BeerSet”:null,“BeerAnn”:null,“FridgeTemp”:19.13,“FridgeSet”:null,“FridgeAnn”:null,“Log1Temp”:22.88,“Log2Temp”:null,“Log3Temp”:null,“State”:0}
Mar 24 2018 16:21:43 {“BeerTemp”:19.69,“BeerSet”:null,“BeerAnn”:null,“FridgeTemp”:19.19,“FridgeSet”:null,“FridgeAnn”:null,“Log1Temp”:22.88,“Log2Temp”:null,“Log3Temp”:null,“State”:0}
Mar 24 2018 16:22:44 {“BeerTemp”:19.69,“BeerSet”:null,“BeerAnn”:null,“FridgeTemp”:19.19,“FridgeSet”:null,“FridgeAnn”:null,“Log1Temp”:null,“Log2Temp”:null,“Log3Temp”:null,“State”:0}
Mar 24 2018 16:23:44 {“BeerTemp”:19.75,“BeerSet”:null,“BeerAnn”:null,“FridgeTemp”:19.19,“FridgeSet”:null,“FridgeAnn”:null,“Log1Temp”:null,“Log2Temp”:null,“Log3Temp”:null,“State”:0}
Mar 24 2018 16:24:45 {“BeerTemp”:19.75,“BeerSet”:null,“BeerAnn”:null,“FridgeTemp”:19.25,“FridgeSet”:null,“FridgeAnn”:null,“Log1Temp”:null,“Log2Temp”:null,“Log3Temp”:null,“State”:0}
Mar 24 2018 16:25:45 {“BeerTemp”:19.75,“BeerSet”:null,“BeerAnn”:null,“FridgeTemp”:19.25,“FridgeSet”:null,“FridgeAnn”:null,“Log1Temp”:null,“Log2Temp”:null,“Log3Temp”:null,“State”:0}
Mar 24 2018 16:26:46 {“BeerTemp”:19.75,“BeerSet”:null,“BeerAnn”:null,“FridgeTemp”:19.25,“FridgeSet”:null,“FridgeAnn”:null,“Log1Temp”:null,“Log2Temp”:null,“Log3Temp”:null,“State”:0}
Mar 24 2018 16:27:46 {“BeerTemp”:67.55,“BeerSet”:null,“BeerAnn”:null,“FridgeTemp”:66.65,“FridgeSet”:null,“FridgeAnn”:null,“Log1Temp”:null,“Log2Temp”:null,“Log3Temp”:null,“State”:0}
Mar 24 2018 16:28:47 {“BeerTemp”:67.55,“BeerSet”:null,“BeerAnn”:null,“FridgeTemp”:66.76,“FridgeSet”:null,“FridgeAnn”:null,“Log1Temp”:null,“Log2Temp”:null,“Log3Temp”:null,“State”:0}
Mar 24 2018 16:29:47 {“BeerTemp”:68.11,“BeerSet”:null,“BeerAnn”:null,“FridgeTemp”:68.11,“FridgeSet”:null,“FridgeAnn”:null,“Log1Temp”:null,“Log2Temp”:null,“Log3Temp”:null,“State”:0}
Mar 24 2018 16:30:48 {“BeerTemp”:69.69,“BeerSet”:null,“BeerAnn”:null,“FridgeTemp”:70.36,“FridgeSet”:19.80,“FridgeAnn”:null,“Log1Temp”:null,“Log2Temp”:null,“Log3Temp”:null,“State”:4}
Mar 24 2018 16:31:48 {“BeerTemp”:70.14,“BeerSet”:null,“BeerAnn”:null,“FridgeTemp”:70.81,“FridgeSet”:19.80,“FridgeAnn”:null,“Log1Temp”:null,“Log2Temp”:null,“Log3Temp”:null,“State”:4}
Mar 24 2018 16:32:49 {“BeerTemp”:70.59,“BeerSet”:null,“BeerAnn”:null,“FridgeTemp”:71.04,“FridgeSet”:60.00,“FridgeAnn”:null,“Log1Temp”:null,“Log2Temp”:null,“Log3Temp”:null,“State”:4}
Mar 24 2018 16:33:49 {“BeerTemp”:70.70,“BeerSet”:null,“BeerAnn”:null,“FridgeTemp”:71.04,“FridgeSet”:60.00,“FridgeAnn”:null,“Log1Temp”:null,“Log2Temp”:null,“Log3Temp”:null,“State”:4}
Mar 24 2018 16:34:50 {“BeerTemp”:71.04,“BeerSet”:null,“BeerAnn”:null,“FridgeTemp”:71.15,“FridgeSet”:60.00,“FridgeAnn”:null,“Log1Temp”:null,“Log2Temp”:null,“Log3Temp”:null,“State”:4}
Mar 24 2018 16:35:50 {“BeerTemp”:70.93,“BeerSet”:null,“BeerAnn”:null,“FridgeTemp”:71.15,“FridgeSet”:60.00,“FridgeAnn”:null,“Log1Temp”:null,“Log2Temp”:null,“Log3Temp”:null,“State”:4}
Mar 24 2018 16:36:51 {“BeerTemp”:71.15,“BeerSet”:null,“BeerAnn”:null,“FridgeTemp”:71.15,“FridgeSet”:60.00,“FridgeAnn”:null,“Log1Temp”:null,“Log2Temp”:null,“Log3Temp”:null,“State”:4}
Mar 24 2018 16:37:52 {“BeerTemp”:71.26,“BeerSet”:null,“BeerAnn”:null,“FridgeTemp”:71.26,“FridgeSet”:60.00,“FridgeAnn”:null,“Log1Temp”:null,“Log2Temp”:null,“Log3Temp”:null,“State”:0}
Mar 24 2018 16:38:53
The last message in your script suggests you clicked the stop button yourself. Did you click it again to start the script?
Sorry, I think I found a bug! I’ll push the fix after dinner.
Sorry about that, that bug was my fault! I have pushed a fix.
The start button should work again after you update.
Please go to the brewpi container in portainer and click ‘recreate container’ and leave ‘pull latest image’ checked.
