Hello guys, I didn’t have the time to setup my new BrewPi spark 3 and still using my old Arduino Uno Rev C.
The notebook in which I was running the web interface stops working and I installed a new one with Debian “Jessie”, the old one was running Debian “Wheezy” with no problems using the Legacy branch and Arduino code v0.2.10.
After setting up the new notebook, I wasn’t able to start the script and I’m having several errors:
brewpi@brewpi:~$ sudo -u brewpi python /home/brewpi/brewpi.py
Jun 24 2018 19:24:55 Opening serial port
Jun 24 2018 19:24:55 Notification: Script started for beer ‘My First BrewPi Run’
Jun 24 2018 19:25:05 Checking software version on controller…
Jun 24 2018 19:25:05 Found BrewPi v0.2.10 build unknown, running on an Arduino Uno with a revC shield on port /dev/ttyACM0
File “/home/brewpi/brewpi.py”, line 415, in
startBeer(config[‘beerName’])
File “/home/brewpi/brewpi.py”, line 287, in startBeer
setFiles()
File “/home/brewpi/brewpi.py”, line 256, in setFiles
os.makedirs(wwwDataPath)
File “/usr/lib/python2.7/os.py”, line 157, in makedirs
mkdir(name, mode)
OSError: [Errno 13] Permission denied: ‘/var/www/html/data/My First BrewPi Run/’
Exception in thread Thread-1 (most likely raised during interpreter shutdown):
File “/usr/lib/python2.7/threading.py”, line 810, in __bootstrap_inner
File “/usr/lib/python2.7/threading.py”, line 763, in run
File “/home/brewpi/backgroundserial.py”, line 81, in __listenThread
File “/usr/local/lib/python2.7/dist-packages/serial/serialutil.py”, line 590, in inWaiting
File “/usr/local/lib/python2.7/dist-packages/serial/serialposix.py”, line 467, in in_waiting
<type ‘exceptions.AttributeError’>: ‘NoneType’ object has no attribute ‘ioctl’
brewpi@brewpi:~$
And in Device Configuration --> Device List web interface:
Error while receiving device configuration: SyntaxError: Unexpected token C in JSON at position 0
I reinstalled the notebook twice with no luck, at this point seems that Jessie doesn’t work with BrewPi, but on the other hand, I could run it when I tested my new BrewPi Spark 3 in a VM in my MAC, so I’m a bit confused what is going wrong here.
Thanks in advance.
Nor.
