Script not running
I’ve had my BrewPi up and running for days- just testing on my desk.
Today I went to update the firmware. The update failed.
I retried a few more times, but after the last time I’m getting a Script not Running on the web interface.
I may have also powered off/on the BrewPi in order to check the firmware version. This involved unplugging both the AC adapter and the USB cable.
I’ve tried powering everything on/off several times, its not fixing it.
brewpi.py --status shows: No BrewPi scripts running
autoSerial.py shows:
All ports: ((’/dev/ttyACM0’, ‘ttyACM0’, ‘USB VID:PID=2b04:c006 SNR=00000000050C’),)
Compatible ports: ((’/dev/ttyACM0’, ‘Particle Photon’),)
Selected port: (’/dev/ttyACM0’, ‘Particle Photon’)
Disregard- this problem went away
