I hit the button to run the script but it does not respond. The log is showing this error:
Could not open port socket://192.168.1.181:6666: [Errno 111] Connection refused
I should mention that this happened in the middle of a brew.
Cant access the portainer page now either.
I removed and added back the portainer and brewpi container but I’m still getting this in the logs:
Aug 03 2017 00:20:04 Notification: Script started for beer 'Pliny the Elder DIPA’
Aug 03 2017 00:20:04 Connecting to controller…
Aug 03 2017 00:20:04 Opening serial port
Aug 03 2017 00:20:15 Errors while opening serial port:
Any ideas @elco?
Have the same issue. Rebooting the brewpi itself solves it temporary for me.
@sbron When the brewpi reboots does it lose the profile its running? I have a beer in and would hate to see it spike the temperature or something.
When i reboot my brewpi it continues the same as before the reboot. But the difference is that i can connect again
But notice i did it when the brewpi was idle. I don’t know exactly what happens if the brewpi was cooling/heating at that moment. Maybe after reboot the dead timer must expire before cooling/heating again?
That did it! It was idle when I power cycled it. When I reloaded the page it showed the script running and everything like normal. I was figuring all of that data was going to be lost… whew!
Thanks for the tip!
I hope this is fixed in 0.5.3-rc.2
You can try it, but it is a pre-release that hasn’t had much testing.
