Anyone have a tutorial on installing a second copy of the container for a second instance of Brewpi?
I’ve done it. All you have to do is give each container a different name and a different location for the data. Then when you open the web browser and go to the maintenance panel you can select the IP address of each spark (assuming you are using wifi).
Thanks. Guess it wasn’t as complicated as I thought.
