Trying to set up a HiHi temp trip to deenergize the RIMS Tube Heater. This is a new brewery following a fire caused by a pump failure and resulting RIMS dry element. I have a One-Wire sensor at the discharge of the RIMS Tube.
When I add a logic actuator to accomplish this, it does not allow me to select an individual temperature sensor, only a setpoint block. This seems confusing. Can you point me in the proper direction to accomplish this?
Ric
