I just flashed the latest version of HypriotOS, v0.7.9, to my SD card. However, /boot doesn’t contain device-init.yaml in this version of the OS… How do can we set up our WiFi with the latest version of HypriotOS? A procedure on how to do that would be very helpful
Right on. From what I can gather, device-init.yaml doesn’t exist anymore in v1.7.0 and beyond. The BrewPi Wiki is written in the context of pre-v1.7.0 (as you’re using). For now I’m gonna format my SD card and try it with v1.6.0 so I can (hopefully) get back up and running faster.
You might find it easier to just use the latest Raspbian image (Stretch) as it works fine. I did ensure that I did an update on apt and then pulled down the latest docker first though.
+1 for just using Raspian and pulling the docker package through the repos. I think it will be more stable, less likely to see configuration files moved around and make finding generic OS installation support easier. For our very low intensity needs, I don’t think whatever optimizations a docker specialized OS provides are really necessary.
I think you have a good point. Hypriot had its place when docker wasn’t support on normal raspbian yet. I’ll give that a shot and rewrite the wiki.
Will also make it much easier for users to switch to docker. No need to re-image.
Only thing I struggled with is the BrewPi container was getting access denied to opening the USB port for the BrewPi. I had to run chmod a+rw /dev/ttyACM0 to allow the container to access. I added it to /etc/rc.local but I assume there is a better way to do that
