We wanted to setup a fermentation system and to make sure we got all your progress included we did a re-installation of the system and updated both bootloader and flash on the spark.
Now the spark-one service is connected and we can read the ports on it, but if we try to toggle the ports is stalls really long time. We have done one succesfull toggle from off to on but it took aprox. 2 minutes. In that time the GUI was showing the ‘await’ icon on the on/off button as to indicate it was executing command. So that part worked nicely. It was indicating current state, when i press “set pin high” it started indicating the ‘await’ circle and after 2 minutes it shown pin was high, which was also the fact, since the pin had changed as requested. Only issue was the 2 minutes delay.
Now system is really struggling. We have tried booting both the PC running Linux mint and the brewblox installation as well as the spark3.
After reboot, the both report in nicely and the current state is reported. Issues begin when we want to change pin settings.
I have extracted a log and hope that anyone here has an idea of the problems we are facing.
slowresponce.pdf (88.6 KB)
Thanks in advance.
Br Ole
