I got a new BrewPi and provided my own Photon. After flashing the firmware using the flashDFU.py script, the device isn’t listed under lsusb or /dev/ttyA* so the script is unable to open the serial port. Below is the output from flashDFU
root@BrewPi-1:/home/brewpi/utils# python flashDfu.py
Detecting DFU devices
Found 1 devices: ['2b04:d006']
Latest stable version on GitHub: 0.2.11
downloading https://github.com/BrewPi/firmware/releases/download/0.2.11/brewpi-0.2.11-photon.bin
Firmware downloaded to /home/brewpi/utils/downloads/0.2.11/brewpi-0.2.11-photon.bin
downloading https://github.com/BrewPi/firmware/releases/download/0.2.11/system-part1-09dd809-photon.bin
downloading https://github.com/BrewPi/firmware/releases/download/0.2.11/system-part2-09dd809-photon.bin
Release contains updated system firmware for the photon
First updating system firmware for the Photon
dfu-util 0.7
Opening DFU capable USB device... ID 2b04:d006
Found DFU: [2b04:d006] devnum=0, cfg=1, intf=0, alt=0, name="@Internal Flash /0x08000000/03*016Ka,01*016Kg,01*064Kg,07*128Kg"
Claiming USB DFU Interface...
dfuIDLE, continuing
No valid DFU suffix signature
Downloading to address = 0x08020000, size = 248764
File downloaded successfully
dfu-util 0.7
dfuIDLE, continuing
Downloading to address = 0x08060000, size = 150432
Now writing BrewPi firmware /home/brewpi/utils/downloads/0.2.11/brewpi-0.2.11-photon.bin
dfu-util 0.7
dfuIDLE, continuing
Downloading to address = 0x080a0000, size = 57432
Opening serial port
Aug 31 2015 20:14:05 Opening serial port
Aug 31 2015 20:14:15 Errors while opening serial port:
Aug 31 2015 20:14:16 Opening serial port
Aug 31 2015 20:14:26 Errors while opening serial port:
Aug 31 2015 20:14:27 Opening serial port
root@BrewPi-1:/home/brewpi/utils# ls /dev/tty*
/dev/tty /dev/tty19 /dev/tty3 /dev/tty40 /dev/tty51 /dev/tty62
/dev/tty0 /dev/tty2 /dev/tty30 /dev/tty41 /dev/tty52 /dev/tty63
/dev/tty1 /dev/tty20 /dev/tty31 /dev/tty42 /dev/tty53 /dev/tty7
/dev/tty10 /dev/tty21 /dev/tty32 /dev/tty43 /dev/tty54 /dev/tty8
/dev/tty11 /dev/tty22 /dev/tty33 /dev/tty44 /dev/tty55 /dev/tty9
/dev/tty12 /dev/tty23 /dev/tty34 /dev/tty45 /dev/tty56 /dev/ttyAMA0
/dev/tty13 /dev/tty24 /dev/tty35 /dev/tty46 /dev/tty57 /dev/ttyprintk
/dev/tty14 /dev/tty25 /dev/tty36 /dev/tty47 /dev/tty58
/dev/tty15 /dev/tty26 /dev/tty37 /dev/tty48 /dev/tty59
/dev/tty16 /dev/tty27 /dev/tty38 /dev/tty49 /dev/tty6
/dev/tty17 /dev/tty28 /dev/tty39 /dev/tty5 /dev/tty60
/dev/tty18 /dev/tty29 /dev/tty4 /dev/tty50 /dev/tty61
root@BrewPi-1:/home/brewpi/utils# ls /dev/U*
ls: cannot access /dev/U*: No such file or directory
root@BrewPi-1:/home/brewpi/utils# ls /dev/u*
/dev/uinput /dev/urandom
