The first time I tried this build, it worked flawlessly except I did not run the permission fix, and therefor could not change or edit the beer profile. The only way I could move the rpi to a monitor was to unplug it as I putty was not working. In doing so, the Pi corrupted.
Here are my steps exactly:
I reformatted my microSD card with the SDFormatter utility. I downloaded NOOBS 1.4.1 and installed. I ran the update, upgrade, and rpi-update and rebooted after each. I cloned the git hub and installed using the commands provided on the walk through. After the install, the web interface is up and running. I reboot, and the pi fails.
I don’t understand why it worked so easily the first time, and now this is my second day and 4th attempt to get this to work.
The only thing I can think of are the updates and the arduino. Are the updates too new and therefor causing a problem? Does the arduino need to be connected?
I suspect this has happened every time because when I move the rpi after all the installs to the fermentation location and connect it to the arduino, nothing happens, no internet, nothing. I do not have a spare monitor to move with the pi, unfortunately, and with no internet, no way to run putty.
I do not know if the SD card is on the verified list. I’ve used it without issue the last year or so. I will check tomorrow (I have to pick up my mom at the airport in about 5 minutes).
I am powering it with a 2A supply, but it also happens to be a phone charger.
It will not boot with, or without the arduino.
I have tried rebooting in both locations with the same outcome.
Brewpi worked flawlessly for 2 weeks prior to this attempt to fix permissions.
