From the log and the screenshot, it looks like the cooler is active.
Check your PID graph to see what perhaps caused the instability. I suspected it is the D part, because your Td value quite high at 1800s. I would keep Td at zero or a very low value unless you have overshoot. That will give you a smoother PWM setting.
I haven’t touched the tuning since forever and have not seen a change like this. Were you able to look at the display going blank ?? This is new, I’ve never seen this happen before…
I’m finishing up a beer now but I"ll check the tuning change.
So my fermenter is at a point I can play with it. Thinking of doing a fresh install.
I did brewblox-ctl snapshot save and at the end it returned this…
tar: brewblox/victoria/data/small/2025_09: file changed as we read it
Command ‘sudo tar -C /home/pi --exclude .venv -czf …/brewblox-snapshot.tar.gz b
rewblox’ returned non-zero exit status 1.
