2 weeks into a fermentation, the display on the Spark 3 froze.
Data kept logging correctly and never showed any anomalies.
Relay control also kept working correctly.
Screen has remained frozen for another 2 weeks.
I will be updating software now.
Configuration notes:
Release 11/2/21.
Spark 3 attached to a Raspberry Pi via USB.
2 expansion boards attached to Spark 3.
1 expansion board has a few temp probes and a relay on it.
The other expansion board has a 3rd expansion board and a relay on it.
3rd expansion board has a couple of temp probes and a couple relays on it.
The display is connected to the board with a ribbon connector. It can happen that this connector becomes slightly unseated. If you open the controller, and press the connector, does this solve the problem?
We fixed a bug in last weeks release that could cause system freeze.
It was a bug in the system layer supplied by particle that caused the system to hang instead or reboot on a serious crash. It took a while before particle accepted and released our fix.
