Hi, I just received by new Brewpi Spark Photon and it white screened out of the box (no beeps). I have just installed and updated the Brewpi software to the latest versions via the script on my raspberry pi. I have put my controller in DFU mode and launched the flashDfu.py script. It updates the firmware and then it Resets the EEPROM to defaults. At this stage it try’s to open a serial connection and hangs.
The controller itself is in stylus setup mode but I cannot click on cross as the touch screen is unresponsive. What do I do now? Output from the script is posted below.
Release contains updated system firmware for the photon
First updating system firmware for the Photon
dfu-util 0.7
Opening DFU capable USB device... ID 2b04:d006
Found DFU: [2b04:d006] devnum=0, cfg=1, intf=0, alt=0, name="@Internal Flash /0x08000000/03*016Ka,01*016Kg,01*064Kg,07*128Kg"
Claiming USB DFU Interface...
dfuIDLE, continuing
No valid DFU suffix signature
Downloading to address = 0x08020000, size = 248764
File downloaded successfully
dfu-util 0.7
dfuIDLE, continuing
Downloading to address = 0x08060000, size = 150432
Now writing BrewPi firmware /home/brewpi/utils/downloads/0.2.11/brewpi-0.2.11-photon.bin
dfu-util 0.7
dfuIDLE, continuing
Downloading to address = 0x080a0000, size = 57432
Opening serial port
Oct 10 2015 18:48:48 Opening serial port
When it arrives, let me know if it solves your problem.
