Dear Team,
I am trying to run a spark simulation on a second raspberry pi. I am hoping to be able to use this to build/experiment with a Herms setup, which I am hoping to move over too in the future.
I have followed the instruction to install Brewblox on the new RPi, but when I run the command to install the Spark simulation service, I receive the following information/error.
"pi@raspberrypi:~/brewblox $ brewblox-ctl add-spark --name spark-one --force --simulation
brewblox-ctl requires extensions that match your Brewblox release. Do you want to download them now? [Press ENTER for default value ‘Yes’]
SHELL docker rm ctl-lib
SHELL docker pull brewblox/brewblox-ctl-lib:edge
5eb93336973f: Pull complete
Digest: sha256:25c0236eb0a7c4fecf37bc4bc1219d2e5e3023adbd4e361decb37b9dfffdc0c8
Status: Downloaded newer image for brewblox/brewblox-ctl-lib:edge
SHELL docker create --name ctl-lib brewblox/brewblox-ctl-lib:edge
dc0c7106fd922274d0dce6bfe066a1092a75e2baaf415fa7965089a0cdf23f14
SHELL rm -rf ./brewblox_ctl_lib
SHELL docker cp ctl-lib:/brewblox_ctl_lib ./
ctl-lib
[Errno 2] No such file or directory: ‘docker-compose.yml’"
Am I missing something, or does this have to be installed along side an existing Spark controller.
Grateful for any advice or pointers to correct process.
Cheers
Stuart
