Spark v3 led status
Hi my spark 3 led status is flashing green very quickly with an occasional white light. Is that normal?
https://docs.particle.io/tutorials/device-os/led/photon/#looking-for-internet
Flashing green means it’s looking for Wifi.
Thanks Bob is there an easy way for me to disable it as i don’t use wireless keep it cabled
I’m afraid not. If it’s in range of a Wifi network, you may as well connect it. Cabled devices always get priority during discovery anyway.
You can clear the WiFi credentials as described here:
https://docs.particle.io/tutorials/device-os/led/photon/#wi-fi-network-reset
However, after a firmware update that has a system layer or bootloader the Spark will download these from the Particle cloud, which requires WiFi.
They can be flashed over USB to, but with WiFi it is a bit more cable of fixing itself.
Thanks both great service as per usual
