Have just received my new v3 but when booting it up for the first time it has a black screen and a constant flashing blue light. from my understanding it should boot up in test mode. is this a firmware issue?
Thanks!!
Thanks!!
Maybe we accidentally shipped it without programming it first.
If you follow the BrewBlox install guide at brewblox.netlify.com you will flash it yourself just like we should have done already.
After the flash, you probably also have to run ābrewblox-ctl bootloaderā before it will start normally.
WiFi can be configured from the web interface on the spark page while it is still connected with USB.
thanks for the quick reply
will give it a go
Thanks!!
have flashed the unit and now the blue light is flashing at a slower pace and i have 6 unassigned boxes on the screen.
have tried running the bootloader but seems to be failing
error is showing
Command ādocker run -it --rm --privileged -v /dev:/dev brewblox/firmware-flasher:edge flash-bootloaderā returned non-zero exit status 1.
thanks
Power cycle the spark (unplug, plug), then run the following commands:
brewblox-ctl particle
particle usb safe-mode
bash ./flash-bootloader
exit
This will put the Spark in safe mode before flashing the bootloader.
still seem to be having the same issue.
this is what i am getting
pi@raspberrypi:~/brewblox $ brewblox-ctl particle
INFO Pulling flasher imageā¦
Digest: sha256:ac8c5180d4f4cb9adbe39587b39caf1df99ed1e5b13341225ded750866c244c2
INFO Stopping servicesā¦
INFO Starting Particle imageā¦
INFO Type āexitā and press enter to exit the shell
bash-5.0# exit
exit
pi@raspberrypi:~/brewblox $ brewblox-ctl bootloader
INFO Flashing bootloaderā¦
Request timeout
You seem to immediately exit the Particle container.
The idea is to start it - it will then display the prompt that you can exit by typing exit. Donāt do that immediately.
In the Particle container, run
After that is done, exit by typing exit and pressing enter.
thanks
still seems to be timing out.
bash-5.0# particle usb safe-mode
Request timeout
am i doing this correctly?
Yes. Youāre just running into an issue with the underlying system libraries. Weāll be releasing a fix for it in the next few days, but until then itās rather annoying.
You can manually put the system in safe mode:
bash ./flash-bootloader in the particle image.i have released SETUP while flashing magenta but now it is flashing blue. what shall i do?
If you saw those 6 boxes, it is already running.
You donāt need the bootloader update.
@bob, bootloader fail is because of the listening mode bug that I just reported at particle. But it only occurs when the app is already running and a bootloader flash is not needed.
Just proceed with the guide. Skip WiFi setup and do that from the UI later.
ok⦠so what shall i do now? i have now lost the the boxes and have a fast flashing blue light
After power cycle youāll be back at slow blue. Thatās just no WiFi configured. It will work over USB. Set up WiFi later from the browser.
If needed, run brewblox-ctl flash again, in case you wiped the Brewblox app with a factory reset.
ok now back to 6 boxes and slow blue light. should it now be in test mode? how do i get to the browser, when typing in the ip address of the pi it takes me to a brewpi setup page, is this correct?
Test mode was something in BrewPi, not Brewblox.
You should not follow a BrewPi install guide, but the Brewblox guide on netlify.
If you followed the BrewPi guide, I would start fresh putting raspbian on the pi and follow the getting started guide for BrewBlox.
After the getting started guide you can use the one of the wizards in the web interface to configure the spark for your process.
ok thanks will start again and follow the Brewblox guide, when does the BrewPi firmware come in to play?
Never. Brewblox fully replaces BrewPi, including the firmware. We will change our branding soon and will officially release Brewblox as a platform.
thanks all working now
New owner here.
where is the guide?
Steve
