Spark V3 White Screen
Hello,
I received one of the BrewPi from the December 7th production run and I am getting a white screen intermittently. It is controlling the fridge fine, but the display will go white occasionally. I can get the screen to work properly only after power cycling the unit 5-10 times. Searching the forums, I see that this issue has occurred before, but i have not seen any fix other than replace the screen.
Maybe the display connector is just not locked properly. Can you check that the flat cable is inserted all the way and that the black locking clips are pushed in all the way?
I reinserted the ribbon cable and the screen powered up correctly. Hopefully that will fix the issue. Thank you for your help!
