Besides a permanent DHCP lease, is there truly no way to set a static IP for the Spark 3? I don’t see anything on this forum and I’ve searched Particle Photon forums too. I can certainly setup a permanent lease if I have to.
The Spark 3 does not support setting a static IP address. Is there an underlying reason for the question? Fixed DHCP leases are better than static IPs in the overwhelming majority of use cases.
Just consistency in my network, which isn’t a good enough reason to avoid a fixed lease. Thanks for the confirmation.
