Step View not updating pump PWM
I’m experiementing a bit with the step view widget which seems to be a good start for automating my HERMS system.
As far as I learned so far, enabling/disabling blocks, setting target temperatures etc. seems to work fine, but changing the “Duty setting” for a non-driven PWM (in my case a pump PWM) does not work.
Is this a bug or am I doing something wrong?
Kind regards
Wolfgang
I’ll have a look to see what’s going on there.
Edit: that’s indeed a bug. The step view tries to change a read-only field. The next release will include a fix.
Any timeline when the next release will be available?
Monday, most likely.
