Hi Elco, can you confirm that your kettle inlets, outlets and HERMS coil etc use BSPP (straight) threads and therefore must be coupled to BSPP female fittings?
I understand that BSPT(tapered) male fittings will work with a BSPP female fittings but not the other way around, so I assume your ball valves, tees, couplers etc are also BSPP?
The threaded parts are indeed BSPP. The ball valves are also BSPP.
From what I understood, most female parts are BSPP and most standard male parts are BSPT.
Mating BSPP with BSPP has the advantage that it is not tight in just one position: you have a bit of room to line up the parts the way you want them and with teflon tape it seals properly.
Cool, thanks for confirming. Parallel threads are just fine with a bit of teflon tape for sure. Your probably right that female parts are generally BSPP, although BSPT ball valves are not uncommon (I have a few) so this is something to watch out for. Not a problem if buying everything from the BrewPi store of course
