I can’t see the tri-clamp temp sensors in the store anymore. Have you stopped selling them, @Elco?
I discovered a problem with them and they’re sent back to the manufacturer. The sensor inside was mounted close to the base instead of the tip.
They are currently making a new batch to replace the faulty batch.
Any update on these?
Only other option is to buy from the US, with import duties and all those boring things.
Cheers
Yes, received replacements now.
I have to do some quick testing and I’ll add them back to the store.
Any chance you could sell a longer sensor? I want to measure the beer temp further inside the tank. Double length maybe? Or is there a way to use an off the shelf RTD?
