Temperature sensor type
Hi.
Is your threaded onewire temperature sensor a DS18B20?
I have tried to use it to replace a DS18B20 sensor in my arduino project , but the sensor does not appear.
Yes it is. Do you have a 4k7 pullup resistor?
Did you connect red to 5V, black to GND and white to your data pin?
Yes I have 4.7k pullup resistor, and the wiring is correct.
my setup is working with another DS18B20 I have, but when I try to use the threaded onewire temperature sensor, i’m not getting any data.
Sensor failure?
Any luck on the threaded temperature sensor?
I have same problem…
The threaded sensor has the same internals as the regular one. This is not the problem.
My problem was in the connection, a bad plug on the supplied cable.
Works fine now.
