It looks like you’re using the j616s version of the tilt service.
To fix, run
brewblox-ctl service remove tilt
brewblox-ctl add-tilt
To fix, run
Woila! yes it works. I thought that it was the j616s versjon/Github I should use so I use it. ut s we speak, I was reading some other post (the long one) about the Tilt, and in ne of the latest post I find the add-tilt command and tryed that, and then it showed up. But now I had a remove-tilt also first.
Thank you @Bob_Steers for the solution.
Cheers! and greeetings from Norway.
Sorry! Should have done that long ago! I’ve added a note to the readme pointing to your service, and I’ve set the github repo to archived which puts a prominent banner at the top. I’ve deleted the dockerhub repo. Obviously, this may result in some fallout from people on the legacy service. But that’s probably better than people relying on massively out of date docker images! Which reminds me. I really need to give my brewblox setup some TLC
Thanks! We are working on some final things for a huge release, so I would postpone that TLC until that release.
where can I find the instructions?
so easy
thank you!
