Trouble with Graph widget
I had an issue with a corrupt SD card on my Raspberry Pi so I did a fresh install of the O/S to an NVMe SSD and restored brewblox from a backup snapshot. All appears to be working correctly however my graph widget is giving “Request failed with status code 500”. Also my session log (which has been running since 26th Dec 2024 when I started fermenting a new brew) is showing “No data (yet) for selected period”.
Is there any troubleshooting I can execute to determine what is going wrong?
Note that I had 2 dashboard, one for brewing and one for fermenting and both exhibit the same behavior.
Please share the output of brewblox-ctl log.
And ctrl-refresh your browser.
ctrl-refresh exhibits the same behavior.
Here’s the log:
https://termbin.com/tbbq
The logs suggest corrupted data for Victoria.
So the corrupted files were added to the snapshot and restored.
You have to remove the corrupted files or the entire Victoria directory.
Thanks @Elco. For now I have just renamed the Victoria directory and will see if I can recover any of the data at a later point.
