Hello,
I have brewblox up and running, but now I am stuck, and really need some help.
To learn the system, I tried a few single sensor control chains, all went fairly well, until I configured the Herms setup via the wizard.Then, I deleted the BK part, and tried the HLT and MT setup.
The system is producing some kind of output on the digital actuator, (SSR and heater function) but both the HLT and MT sensors seem to be stuck in kind of ‘a coma’,
no readout on Spark V2 display, just dashes…
I tried other settings in dialog boxes, unplugged sensors, restarted Spark, went through troubleshooting posts, etc, no result.
In the end, I opted for a fresh install after formatting SD card, according to the ‘getting started’ steps.
I would have thought to have a blank system, but to my surprise, the Spark controller seemed to have ‘found’ the old service, and the display was still showing the ‘deleted’ display settings.
I then run through the wizard to setup the Herms again, deleted blocks that I didn’t need, and also deleted the retained blocks of the former setup. I am back to square one, and still stuck.
I am quite sure the software got installed well, but it seems like I have somehow messed up the service on the rpi.
So I better wait until you publish an in depth user guide, since the functionality of the system is not completely clear yet for me.
I did include the system logs if you would want to have a look into it.
Thank you in advance.
brewblox-blocks-spark-one.json (4.0 KB) brewblox-logs.json (228 Bytes)
https://termbin.com/76lo
