Unsecure Website Error
That’s normal, and to be expected.
We don’t even attempt to support IE anymore, so no surprise there either.
With it working in Firefox, I suspect that there’s a flag in chrome somewhere that completely blocks self-signed certificates.
You could try this guide to accepting certificates: https://www.pico.net/kb/how-do-you-get-chrome-to-accept-a-self-signed-certificate
I figured IE was not addressed, just added for completeness.
I’m okay with just using Firefox.
And, I’ll look at pico.net later this evening.
Thanks for all your help on this.
Bob,
Sorry be trouble you… again…
Okay, after we conversed this afternoon, I was on the web UI with the Spark and I received a request to update the firmware. The update did not complete. Instructions said to do this thru the terminal view, so I ran the update via putty, successfully (I did have to try this a couple of times). After which, the blue led on the Spark was flashing, so I ran the particle/bootloader command. This was successful.
Now, the Spark is displaying the correct blocks and controlling my fermentation chamber correctly, BUT, when I go to the Web UI (Firefox :slight_smile: ) I am seeing a blank display - none of my blocks are displayed and on the left pop-out window, there is nothing installed in the services area and on the right it says it is waiting for the data store?
At the bottom right, there is a “bell” icon and when I click on it, this error is displayed:
Datastore error: url=undefined, status=undefined, response=timeout of 2000ms exceeded*
Did I forget to bring something back up?
the log is here:
https://termbin.com/91js
(no issues with Termbin, this time!)
regards,
Bob
Logs suggest that everything is currently turned off, so try brewblox-ctl up, and see whether everything starts up ok.
(The flash and bootloader commands indeed first turn off all active services)
You know I thought I did that but apparently not. Everything’s back up. Sorry for troubling you.
