Updated firmware now cant connect to UI
Hello,
I tried to update the Firmware (FW) but kept getting an error so followed some tutorials from here, ive now flashed the boot loader & updated the spark, but now I can/t log into the UI, the ip address is correct as I can log into the PI using putty?
I’d appreciate any help with this issue
Are the services up and running? (brewblox-ctl status). If they are, and the UI still won’t load, could you please run brewblox-ctl log?
tried that command & I get
Error: No such command ‘status’.
pi@raspberrypi:~/brewblox $ pi@raspberrypi:~/brewblox $ brewblox-ctl status
-bash: pi@raspberrypi:~/brewblox: No such file or directory
pi@raspberrypi:~/brewblox $ Usage: brewblox-ctl [OPTIONS] COMMAND [ARGS]…
-bash: Usage:: command not found
pi@raspberrypi:~/brewblox $ Try ‘brewblox-ctl --help’ for help.
-bash: Try: command not found
pi@raspberrypi:~/brewblox $ Error: No such command ‘status’.
-bash: Error:: command not found
https://termbin.com/4jxtb
It looks like your services indeed aren’t active. Run brewblox-ctl up to start them.
Apparently we dropped the brewblox-ctl status command. docker-compose ps does the same thing.
Tried both commands & no change?
https://termbin.com/p04nx
What is the output from brewblox-ctl up?
Hi Bob,
I ran brewblox-ctl upagain & the UI has returned, hopefully I can get the brewery set up with the information provided in my other thread, many thanks
