UpdateFirmware.py FAILED (White screen) [Solved]
I went to update my firmware today by running updateFirmware.py First it failed because on line 115 of updateFirmware.py, the word “Spark” needed to be changed to “Particle” (read that in another thread).
Then I ran updateFirmware.py again and this time it failed because it could not configure port.
Also, now my controller has a grey screen and I can’t make any connection now.
Here’s the last log…please help!
Thank you!
/home/brewpi/utils$ sudo python updateFirmware.py
Stopping any
running instances of BrewPi to check/update controller…
Checking current
firmware version…
Dec 26 2015 15:07:54
Opening serial port
Current firmware
version on controller: 0.2.11
Checking GitHub for
latest release…
Latest version on
GitHub: 0.4.2
Version on GitHub is
newer than your current version, downloading new version…
Downloading latest
firmware…
downloading
https://github.com/BrewPi/firmware/releases/download/0.4.2/brewpi-0.4.2-photon.bin
Latest firmware
downloaded to
/home/brewpi/utils/downloads/0.4.2/brewpi-0.4.2-photon.bin
**** Photon
Program script started ****
Settings will be
restored if possible
Devices will be
Dec 26 2015 15:07:56
Opening serial port
Checking old
version before programming.
Checking current
version: Found BrewPi v0.2.11 build 0.2.11-0-ga28c22d, running on a
Particle Photon with a V2 shield on port /dev/ttyACM0
Requesting old
settings from Photon…
Saved old settings
to file settings-Dec-26-2015-15-07-59.json
sent packet nr 0
sent packet nr 1
sent packet nr 2
sent packet nr 3
sent packet nr 4
sent packet nr 5
sent packet nr 6
sent packet nr 7
sent packet nr 8
sent packet nr 9
sent packet nr 10
sent packet nr 11
sent packet nr 12
sent packet nr 13
sent packet nr 14
sent packet nr 15
sent packet nr 16
sent packet nr 17
sent packet nr 18
sent packet nr 19
sent packet nr 20
sent packet nr 21
sent packet nr 22
sent packet nr 23
sent packet nr 24
sent packet nr 25
sent packet nr 26
sent packet nr 27
sent packet nr 28
sent packet nr 29
sent packet nr 30
sent packet nr 31
sent packet nr 32
sent packet nr 33
sent packet nr 34
sent packet nr 35
sent packet nr 36
sent packet nr 37
sent packet nr 38
sent packet nr 39
sent packet nr 40
sent packet nr 41
sent packet nr 42
sent packet nr 43
sent packet nr 44
sent packet nr 45
sent packet nr 46
sent packet nr 47
sent packet nr 48
sent packet nr 49
sent packet nr 50
sent packet nr 51
sent packet nr 52
sent packet nr 53
sent packet nr 54
sent packet nr 55
sent packet nr 56
sent packet nr 57
sent packet nr 58
sent packet nr 59
sent packet nr 60
sent packet nr 61
sent packet nr 62
sent packet nr 63
sent packet nr 64
sent packet nr 65
sent packet nr 66
sent packet nr 67
sent packet nr 68
sent packet nr 69
sent packet nr 70
sent packet nr 71
sent packet nr 72
sent packet nr 73
sent packet nr 74
sent packet nr 75
sent packet nr 76
sent packet nr 77
sent packet nr 78
sent packet nr 79
sent packet nr 80
sent packet nr 81
sent packet nr 82
sent packet nr 83
sent packet nr 84
sent packet nr 0
File flashed
successfully
Waiting for device
to reset.
Dec 26 2015 15:08:02
Opening serial port
Traceback (most
recent call last):
File
"updateFirmware.py", line 144, in
result =
updateFromGitHub(userInput)
File
"updateFirmware.py", line 124, in updateFromGitHub
{‘settings’:
restoreSettings, ‘devices’: restoreDevices})
File
"/home/brewpi/utils/…/programController.py", line 160, in
programController
return
programmer.program(hexFile, restoreWhat)
File
"/home/brewpi/utils/…/programController.py", line 228, in
program
self.fetch_new_version()
File
"/home/brewpi/utils/…/programController.py", line 311, in
fetch_new_version
self.versionNew
= self.fetch_version(“Checking new version: “)
File
”/home/brewpi/utils/…/programController.py”, line 296, in
fetch_version
version =
brewpiVersion.getVersionFromSerial(self.ser)
File
"/home/brewpi/utils/…/brewpiVersion.py", line 29, in
ser.setTimeout(1)
File
"/usr/local/lib/python2.7/dist-packages/serial/serialutil.py",
line 402, in setTimeout
if self._isOpen:
self._reconfigurePort()
File
"/usr/local/lib/python2.7/dist-packages/serial/serialposix.py",
line 325, in _reconfigurePort
raise
SerialException(“Could not configure port: %s” % msg)
serial.serialutil.SerialException:
Could not configure port: (5, ‘Input/output error’)
rdh@YeastFeast:/home/brewpi/utils$
It sounds like you are trying to work with an outdated version of the script and are making changes to fix things that I have already fixed.
Please run updater.py first to update the python scripts and update the firmware last.
Because you did not use the latest version, you did not update the system firmware, only the user part. This is why you now have a white screen.
To fix this, you will have to put your Photon in DFU mode and run flashDfu.py. (after running updater.py)
Think I’m good now.
I did this:
1.) Ran updater.py
2.) Jammed two micro screwdrivers into the RESET & SETUP holes of my BrewPi Spark v2 Photon box until the status LED light turned from blue to yellow (gets you into DFU mode).
3.) Ran flashDfu.py script.
Looks like it’s in test mode now (which is the first I’ve seen of this) but might be helpful when I finally get around to connecting my fridge up to this thing.
Yes, test mode is the new default mode after a settins reset. As soon as you apply a beer or fridge setpoint it will go out of test mode. It is useful when you are connecting your sensors and SSRs to see whether they work.
