USB power is connected to the 5V input on the Spark. It will never negotiate over USB-C to get 12V or 24V. Power consumption without active peripherals is ~200 mA.
If the problem persists, you can also check Spark debugging output for errors by running
. .venv/bin/activate
pyserial-miniterm /dev/serial/by-id/usb-{PRESS TAB TO AUTOCOMPLETE} 115200
It’ll look something like this. The tab autocomplete is because your controller will have a different name.
(.venv) pi@manyberry:~/brewblox $ pyserial-miniterm /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_f81a3e3d9a71eb11813b496e014bf449-if00-port0 115200
--- Miniterm on /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_f81a3e3d9a71eb11813b496e014bf449-if00-port0 115200,8,N,1 ---
--- Quit: Ctrl+] | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H ---
Just tried an external USB “A” 3 amp power supply with a USB”A” to USB”C” cord. Same issue.
“USB power is connected to the 5V input on the Spark. It will never negotiate over USB-C to get 12V or 24V. Power consumption without active peripherals is ~200 mA.”
Huh? I can power the Spark 4 from a 12 VDC power supply through the 5 VDC USB ”C” port?
Devices can negotiate for 12V / 24V, with a maximum of 100W / 240W, depending on the cable. It’s becoming more common for laptops to replace their power jack with a USB-C port as well.
We don’t use it, because we found out that when the Spark negotiated for 12V, the 5V → 12V switch would interrupt power long enough that the Spark would reboot.
I will get another SD card, reconfigure it and try it out late this week….probably Friday. It will be a good exercise for recovering and reloading the saved user interface file.
