I was wondering if it was possible to use an SSR expansion board as an input? Say for the fridge door?
I know that the DS2413 chips have this functionality, but I was wondering if this was set up in the brewpi software, and if the expansion board could be wired up to achieve this.
I’m really keen for this. For my situation I’m still using an arduino setup. There is a issue with the legacy code that means it can’t be done and doesn’t look like the issue will be fixed for legacy code unfortunately. As far as I’m aware it should be ok for Spark code (@Elco)?
Alarms were one of the reasons I started thinking about this. Also for the sake of complete data logging. It would be good to be able to trace any fluctuations in chamber temp to door events.
