I was wondering if it were possible to use the rj12 connectors to switch 12v relays. I know that the connectors can supply 5v or 12v to boards hardware-wise, but i was wondering if the brewpi software supported switching on the rj12s instead of the 5v digital outputs.
The RJ12 ports only have bus communication protocols on them. All of the signals go through driver IC’s, so it is not possible to switch digital signals directly.
No, it seems that they require 12V to switch. You’d need a transistor too.
Our valve control board has an H-bridge to switch 12V ball valve motors, this could be used to drive the relays.
Why do you want to use these relays? If you want to use PWM, you will be cycling them quickly. They have a limited lifespan, the number of cycles is given in the spec sheet.
