Hello
I have been running my brewery with the Spark 3 for some time now. The other day, out of nowhere, I couldn’t connect to it anymore,
I have looked through all past threads for help, and have tried them all, but it seems to go back where i started: in the UI, it can find the Spark and connect to it, but it stalls when validating controller handshake.
The other day i was succesful in setting up WIFI through the Particle app, but now it gives me an error message - after several attempts.
I have done a full re-install on brewblox on my PI, I have made sure the power supply is 2,4A (in accordance with what I have read here). Is the Spark dead?
Here’s the log from the Spark:
+++++++++++++++++++++++++++++++++++++++++++++++++ Service: sjaiber-spark +++++++++++++++++++++++++++++++++++++++++++++++++
Attaching to brewblox_sjaiber-spark_1
sjaiber-spark_1 | 2023-01-25T08:35:53.505990637Z 2023/01/25 09:35:53 INFO main firmware.ini: {‘firmware_version’: ‘10bb1f6d’, ‘firmware_date’: ‘2023-01-06’, ‘firmware_sha’: ‘10bb1f6d0c63129e333ba4d881cfc649e9c1cae4’, ‘proto_version’: ‘9601ba60’, ‘proto_date’: ‘2023-01-06’, ‘system_version’: ‘3.2.0’}
sjaiber-spark_1 | 2023-01-25T08:35:53.537796090Z 2023/01/25 09:35:53 INFO brewblox_service.service Service name: sjaiber-spark
sjaiber-spark_1 | 2023-01-25T08:35:53.537975415Z 2023/01/25 09:35:53 INFO brewblox_service.service Service info: @ Mon Jan 9 15:21:17 UTC 2023
sjaiber-spark_1 | 2023-01-25T08:35:53.538014635Z 2023/01/25 09:35:53 INFO brewblox_service.service Service config: {‘host’: ‘0.0.0.0’, ‘port’: 5000, ‘name’: ‘sjaiber-spark’, ‘debug’: False, ‘mqtt_protocol’: ‘mqtt’, ‘mqtt_host’: ‘eventbus’, ‘mqtt_port’: None, ‘mqtt_path’: ‘/eventbus’, ‘history_topic’: ‘brewcast/history’, ‘state_topic’: ‘brewcast/state’, ‘simulation’: False, ‘device_host’: None, ‘device_port’: 8332, ‘device_serial’: None, ‘device_id’: ‘1E003A001147383531363134’, ‘discovery’: ‘all’, ‘command_timeout’: 20, ‘broadcast_interval’: 5, ‘volatile’: False, ‘datastore_topic’: ‘brewcast/datastore’, ‘skip_version_check’: False, ‘backup_interval’: 3600, ‘backup_retry_interval’: 300}
sjaiber-spark_1 | 2023-01-25T08:35:53.538056666Z 2023/01/25 09:35:53 INFO brewblox_service.mqtt Starting <EventHandler for mqtt://eventbus:1883>
sjaiber-spark_1 | 2023-01-25T08:35:53.538088542Z 2023/01/25 09:35:53 INFO brewblox_service.mqtt listen(brewcast/datastore/brewblox-global)
sjaiber-spark_1 | 2023-01-25T08:35:53.538119480Z 2023/01/25 09:35:53 INFO brewblox_service.mqtt subscribe(brewcast/datastore/brewblox-global)
sjaiber-spark_1 | 2023-01-25T08:35:53.538149168Z 2023/01/25 09:35:53 INFO brewblox_service.mqtt listen(brewcast/spark/blocks/create)
sjaiber-spark_1 | 2023-01-25T08:35:53.538178699Z 2023/01/25 09:35:53 INFO brewblox_service.mqtt listen(brewcast/spark/blocks/write)
sjaiber-spark_1 | 2023-01-25T08:35:53.538208023Z 2023/01/25 09:35:53 INFO brewblox_service.mqtt listen(brewcast/spark/blocks/patch)
sjaiber-spark_1 | 2023-01-25T08:35:53.538237346Z 2023/01/25 09:35:53 INFO brewblox_service.mqtt listen(brewcast/spark/blocks/delete)
sjaiber-spark_1 | 2023-01-25T08:35:53.538267190Z 2023/01/25 09:35:53 INFO brewblox_service.mqtt subscribe(brewcast/spark/blocks/#)
sjaiber-spark_1 | 2023-01-25T08:35:53.573506906Z 2023/01/25 09:35:53 INFO brewblox_service.mqtt <EventHandler for mqtt://eventbus:1883> connected
sjaiber-spark_1 | 2023-01-25T08:35:53.611392436Z 2023/01/25 09:35:53 INFO …_devcon_spark.service_store read {‘namespace’: ‘spark-service’, ‘id’: ‘sjaiber-spark-service-db’, ‘data’: {‘autoconnecting’: True, ‘retry_interval’: 2}}
sjaiber-spark_1 | 2023-01-25T08:35:53.639188360Z 2023/01/25 09:35:53 INFO …evcon_spark.synchronization Service temperature unit set to degC
sjaiber-spark_1 | 2023-01-25T08:35:53.640661555Z 2023/01/25 09:35:53 INFO …_devcon_spark.connect_funcs Discovering devices… (all)
sjaiber-spark_1 | 2023-01-25T08:35:53.666413755Z 2023/01/25 09:35:53 INFO …_devcon_spark.connect_funcs Discovered [‘/dev/ttyACM0’, ‘P1 - P1 Serial’, ‘USB VID:PID=2B04:C008 SER=1e003a001147383531363134 LOCATION=1-1.4:1.0’]
sjaiber-spark_1 | 2023-01-25T08:35:54.693038900Z 2023/01/25 09:35:54 INFO …lox_devcon_spark.connection <SparkConnection for /dev/ttyACM0> connected
sjaiber-spark_1 | 2023-01-25T08:35:54.733446025Z 2023/01/25 09:35:54 INFO …lox_devcon_spark.connection HandshakeMessage(name=‘BREWBLOX’, firmware_version=‘10bb1f6d’, proto_version=‘9601ba60’, firmware_date=‘2023-01-06’, proto_date=‘2023-01-06’, system_version=‘3.2.0’, platform=‘p1’, reset_reason_hex=‘78’, reset_data_hex=‘00’, device_id=‘1E003A001147383531363134’, reset_reason=‘DFU_MODE’, reset_data=‘NOT_SPECIFIED’)
sjaiber-spark_1 | 2023-01-25T08:35:54.782881076Z 2023/01/25 09:35:54 INFO …ox_devcon_spark.block_store Read 6 blocks
sjaiber-spark_1 | 2023-01-25T08:35:54.851247772Z 2023/01/25 09:35:54 INFO …evcon_spark.synchronization System uptime: 6m29s
sjaiber-spark_1 | 2023-01-25T08:35:54.851941218Z 2023/01/25 09:35:54 INFO …evcon_spark.synchronization System updates per second: 20.674
sjaiber-spark_1 | 2023-01-25T08:35:56.134231152Z 2023/01/25 09:35:56 ERROR …evcon_spark.synchronization Sync subroutine failed: sync controller settings - CommandException(BLOCK_WRITE, INSUFFICIENT_STORAGE)
sjaiber-spark_1 | 2023-01-25T08:35:56.135163195Z 2023/01/25 09:35:56 ERROR …evcon_spark.synchronization Failed to sync: CommandException(BLOCK_WRITE, INSUFFICIENT_STORAGE)
sjaiber-spark_1 | 2023-01-25T08:35:56.137141293Z 2023/01/25 09:35:56 ERROR brewblox_service.repeater error during run(): CommandException(BLOCK_WRITE, INSUFFICIENT_STORAGE)
sjaiber-spark_1 | 2023-01-25T08:35:56.144429770Z 2023/01/25 09:35:56 INFO …lox_devcon_spark.connection <SparkConnection for /dev/ttyACM0> closed stream writer
sjaiber-spark_1 | 2023-01-25T08:35:56.146318805Z 2023/01/25 09:35:56 INFO …lox_devcon_spark.connection <SparkConnection for /dev/ttyACM0> terminated subprocess
sjaiber-spark_1 | 2023-01-25T08:35:56.148201016Z 2023/01/25 09:35:56 ERROR brewblox_service.repeater <SparkConnection for /dev/ttyACM0> error during run(): ConnectionError(EOF received)
sjaiber-spark_1 | 2023-01-25T08:35:56.149245404Z 2023/01/25 09:35:56 INFO …lox_devcon_spark.connection Retrying connection…
sjaiber-spark_1 | 2023-01-25T08:35:56.178611608Z 2023/01/25 09:35:56 INFO …_devcon_spark.service_store read {‘namespace’: ‘spark-service’, ‘id’: ‘sjaiber-spark-service-db’, ‘data’: {‘autoconnecting’: True, ‘retry_interval’: 2}}
sjaiber-spark_1 | 2023-01-25T08:35:56.204825949Z 2023/01/25 09:35:56 INFO …evcon_spark.synchronization Service temperature unit set to degC
sjaiber-spark_1 | 2023-01-25T08:35:58.153113404Z 2023/01/25 09:35:58 INFO …_devcon_spark.connect_funcs Discovering devices… (all)
sjaiber-spark_1 | 2023-01-25T08:35:58.187805039Z 2023/01/25 09:35:58 INFO …_devcon_spark.connect_funcs Discovered [‘/dev/ttyACM0’, ‘P1 - P1 Serial’, ‘USB VID:PID=2B04:C008 SER=1e003a001147383531363134 LOCATION=1-1.4:1.0’]
sjaiber-spark_1 | 2023-01-25T08:35:59.216938705Z 2023/01/25 09:35:59 INFO …lox_devcon_spark.connection <SparkConnection for /dev/ttyACM0> connected
sjaiber-spark_1 | 2023-01-25T08:35:59.253966933Z 2023/01/25 09:35:59 INFO …lox_devcon_spark.connection HandshakeMessage(name=‘BREWBLOX’, firmware_version=‘10bb1f6d’, proto_version=‘9601ba60’, firmware_date=‘2023-01-06’, proto_date=‘2023-01-06’, system_version=‘3.2.0’, platform=‘p1’, reset_reason_hex=‘78’, reset_data_hex=‘00’, device_id=‘1E003A001147383531363134’, reset_reason=‘DFU_MODE’, reset_data=‘NOT_SPECIFIED’)
sjaiber-spark_1 | 2023-01-25T08:35:59.296346999Z 2023/01/25 09:35:59 INFO …ox_devcon_spark.block_store Read 6 blocks
sjaiber-spark_1 | 2023-01-25T08:35:59.316706527Z 2023/01/25 09:35:59 INFO …evcon_spark.synchronization System uptime: 6m33s
sjaiber-spark_1 | 2023-01-25T08:35:59.317059448Z 2023/01/25 09:35:59 INFO …evcon_spark.synchronization System updates per second: 14.527
sjaiber-spark_1 | 2023-01-25T08:35:59.819928347Z 2023/01/25 09:35:59 INFO …ox_devcon_spark.block_store Saved 6 block(s)
sjaiber-spark_1 | 2023-01-25T08:36:00.607000260Z 2023/01/25 09:36:00 ERROR …evcon_spark.synchronization Sync subroutine failed: sync controller settings - CommandException(BLOCK_WRITE, INSUFFICIENT_STORAGE)
sjaiber-spark_1 | 2023-01-25T08:36:00.607523704Z 2023/01/25 09:36:00 ERROR …evcon_spark.synchronization Failed to sync: CommandException(BLOCK_WRITE, INSUFFICIENT_STORAGE)
sjaiber-spark_1 | 2023-01-25T08:36:00.609612428Z 2023/01/25 09:36:00 ERROR brewblox_service.repeater error during run(): CommandException(BLOCK_WRITE, INSUFFICIENT_STORAGE)
sjaiber-spark_1 | 2023-01-25T08:36:00.617070439Z 2023/01/25 09:36:00 INFO …lox_devcon_spark.connection <SparkConnection for /dev/ttyACM0> closed stream writer
sjaiber-spark_1 | 2023-01-25T08:36:00.621225283Z 2023/01/25 09:36:00 INFO …lox_devcon_spark.connection <SparkConnection for /dev/ttyACM0> terminated subprocess
sjaiber-spark_1 | 2023-01-25T08:36:00.621438255Z 2023/01/25 09:36:00 ERROR brewblox_service.repeater <SparkConnection for /dev/ttyACM0> error during run(): ConnectionError(EOF received)
sjaiber-spark_1 | 2023-01-25T08:36:00.621525495Z 2023/01/25 09:36:00 INFO …lox_devcon_spark.connection Retrying connection…
sjaiber-spark_1 | 2023-01-25T08:36:00.648553285Z 2023/01/25 09:36:00 INFO …_devcon_spark.service_store read {‘namespace’: ‘spark-service’, ‘id’: ‘sjaiber-spark-service-db’, ‘data’: {‘autoconnecting’: True, ‘retry_interval’: 2}}
sjaiber-spark_1 | 2023-01-25T08:36:00.676234311Z 2023/01/25 09:36:00 INFO …evcon_spark.synchronization Service temperature unit set to degC
sjaiber-spark_1 | 2023-01-25T08:36:02.625738968Z 2023/01/25 09:36:02 INFO …_devcon_spark.connect_funcs Discovering devices… (all)
sjaiber-spark_1 | 2023-01-25T08:36:02.661689839Z 2023/01/25 09:36:02 INFO …_devcon_spark.connect_funcs Discovered [‘/dev/ttyACM0’, ‘P1 - P1 Serial’, ‘USB VID:PID=2B04:C008 SER=1e003a001147383531363134 LOCATION=1-1.4:1.0’]
sjaiber-spark_1 | 2023-01-25T08:36:03.696560660Z 2023/01/25 09:36:03 INFO …lox_devcon_spark.connection <SparkConnection for /dev/ttyACM0> connected
sjaiber-spark_1 | 2023-01-25T08:36:03.701003998Z 2023/01/25 09:36:03 INFO …lox_devcon_spark.connection HandshakeMessage(name=‘BREWBLOX’, firmware_version=‘10bb1f6d’, proto_version=‘9601ba60’, firmware_date=‘2023-01-06’, proto_date=‘2023-01-06’, system_version=‘3.2.0’, platform=‘p1’, reset_reason_hex=‘78’, reset_data_hex=‘00’, device_id=‘1E003A001147383531363134’, reset_reason=‘DFU_MODE’, reset_data=‘NOT_SPECIFIED’)
sjaiber-spark_1 | 2023-01-25T08:36:03.743897768Z 2023/01/25 09:36:03 INFO …ox_devcon_spark.block_store Read 6 blocks
sjaiber-spark_1 | 2023-01-25T08:36:03.812283683Z 2023/01/25 09:36:03 INFO …evcon_spark.synchronization System uptime: 6m38s
sjaiber-spark_1 | 2023-01-25T08:36:03.812603167Z 2023/01/25 09:36:03 INFO …evcon_spark.synchronization System updates per second: 14.755
sjaiber-spark_1 | 2023-01-25T08:36:05.102950390Z 2023/01/25 09:36:05 ERROR …evcon_spark.synchronization Sync subroutine failed: sync controller settings - CommandException(BLOCK_WRITE, INSUFFICIENT_STORAGE)
sjaiber-spark_1 | 2023-01-25T08:36:05.113422814Z 2023/01/25 09:36:05 ERROR …evcon_spark.synchronization Failed to sync: CommandException(BLOCK_WRITE, INSUFFICIENT_STORAGE)
sjaiber-spark_1 | 2023-01-25T08:36:05.113755266Z 2023/01/25 09:36:05 ERROR brewblox_service.repeater error during run(): CommandException(BLOCK_WRITE, INSUFFICIENT_STORAGE)
sjaiber-spark_1 | 2023-01-25T08:36:05.113830840Z 2023/01/25 09:36:05 INFO …lox_devcon_spark.connection <SparkConnection for /dev/ttyACM0> closed stream writer
sjaiber-spark_1 | 2023-01-25T08:36:05.116060816Z 2023/01/25 09:36:05 INFO …lox_devcon_spark.connection <SparkConnection for /dev/ttyACM0> terminated subprocess
sjaiber-spark_1 | 2023-01-25T08:36:05.116237016Z 2023/01/25 09:36:05 ERROR brewblox_service.repeater <SparkConnection for /dev/ttyACM0> error during run(): ConnectionError(EOF received)
sjaiber-spark_1 | 2023-01-25T08:36:05.116302329Z 2023/01/25 09:36:05 INFO …lox_devcon_spark.connection Retrying connection…
sjaiber-spark_1 | 2023-01-25T08:36:05.144846179Z 2023/01/25 09:36:05 INFO …_devcon_spark.service_store read {‘namespace’: ‘spark-service’, ‘id’: ‘sjaiber-spark-service-db’, ‘data’: {‘autoconnecting’: True, ‘retry_interval’: 2}}
sjaiber-spark_1 | 2023-01-25T08:36:05.176801843Z 2023/01/25 09:36:05 INFO …evcon_spark.synchronization Service temperature unit set to degC
sjaiber-spark_1 | 2023-01-25T08:36:07.120274028Z 2023/01/25 09:36:07 INFO …_devcon_spark.connect_funcs Discovering devices… (all)
sjaiber-spark_1 | 2023-01-25T08:36:07.155039206Z 2023/01/25 09:36:07 INFO …_devcon_spark.connect_funcs Discovered [‘/dev/ttyACM0’, ‘P1 - P1 Serial’, ‘USB VID:PID=2B04:C008 SER=1e003a001147383531363134 LOCATION=1-1.4:1.0’]
sjaiber-spark_1 | 2023-01-25T08:36:08.189118247Z 2023/01/25 09:36:08 INFO …lox_devcon_spark.connection <SparkConnection for /dev/ttyACM0> connected
sjaiber-spark_1 | 2023-01-25T08:36:08.201442986Z 2023/01/25 09:36:08 INFO …lox_devcon_spark.connection HandshakeMessage(name=‘BREWBLOX’, firmware_version=‘10bb1f6d’, proto_version=‘9601ba60’, firmware_date=‘2023-01-06’, proto_date=‘2023-01-06’, system_version=‘3.2.0’, platform=‘p1’, reset_reason_hex=‘78’, reset_data_hex=‘00’, device_id=‘1E003A001147383531363134’, reset_reason=‘DFU_MODE’, reset_data=‘NOT_SPECIFIED’)
sjaiber-spark_1 | 2023-01-25T08:36:08.240033109Z 2023/01/25 09:36:08 INFO …ox_devcon_spark.block_store Read 6 blocks
sjaiber-spark_1 | 2023-01-25T08:36:08.266928240Z 2023/01/25 09:36:08 INFO …evcon_spark.synchronization System uptime: 6m42s
sjaiber-spark_1 | 2023-01-25T08:36:08.267377620Z 2023/01/25 09:36:08 INFO …evcon_spark.synchronization System updates per second: 14.902
sjaiber-spark_1 | 2023-01-25T08:36:08.782936940Z 2023/01/25 09:36:08 INFO …ox_devcon_spark.block_store Saved 6 block(s)
sjaiber-spark_1 | 2023-01-25T08:36:09.553474217Z 2023/01/25 09:36:09 ERROR …evcon_spark.synchronization Sync subroutine failed: sync controller settings - CommandException(BLOCK_WRITE, INSUFFICIENT_STORAGE)
sjaiber-spark_1 | 2023-01-25T08:36:09.553917087Z 2023/01/25 09:36:09 ERROR …evcon_spark.synchronization Failed to sync: CommandException(BLOCK_WRITE, INSUFFICIENT_STORAGE)
sjaiber-spark_1 | 2023-01-25T08:36:09.555590285Z 2023/01/25 09:36:09 ERROR brewblox_service.repeater error during run(): CommandException(BLOCK_WRITE, INSUFFICIENT_STORAGE)
sjaiber-spark_1 | 2023-01-25T08:36:09.562750376Z 2023/01/25 09:36:09 INFO …lox_devcon_spark.connection <SparkConnection for /dev/ttyACM0> closed stream writer
sjaiber-spark_1 | 2023-01-25T08:36:09.563724346Z 2023/01/25 09:36:09 INFO …lox_devcon_spark.connection <SparkConnection for /dev/ttyACM0> terminated subprocess
sjaiber-spark_1 | 2023-01-25T08:36:09.565200667Z 2023/01/25 09:36:09 ERROR brewblox_service.repeater <SparkConnection for /dev/ttyACM0> error during run(): ConnectionError(EOF received)
sjaiber-spark_1 | 2023-01-25T08:36:09.566804021Z 2023/01/25 09:36:09 INFO …lox_devcon_spark.connection Retrying connection…
sjaiber-spark_1 | 2023-01-25T08:36:09.593727642Z 2023/01/25 09:36:09 INFO …_devcon_spark.service_store read {‘namespace’: ‘spark-service’, ‘id’: ‘sjaiber-spark-service-db’, ‘data’: {‘autoconnecting’: True, ‘retry_interval’: 2}}
sjaiber-spark_1 | 2023-01-25T08:36:09.628288547Z 2023/01/25 09:36:09 INFO …evcon_spark.synchronization Service temperature unit set to degC
sjaiber-spark_1 | 2023-01-25T08:36:11.570637853Z 2023/01/25 09:36:11 INFO …_devcon_spark.connect_funcs Discovering devices… (all)
sjaiber-spark_1 | 2023-01-25T08:36:11.605882933Z 2023/01/25 09:36:11 INFO …_devcon_spark.connect_funcs Discovered [‘/dev/ttyACM0’, ‘P1 - P1 Serial’, ‘USB VID:PID=2B04:C008 SER=1e003a001147383531363134 LOCATION=1-1.4:1.0’]
sjaiber-spark_1 | 2023-01-25T08:36:12.638516331Z 2023/01/25 09:36:12 INFO …lox_devcon_spark.connection <SparkConnection for /dev/ttyACM0> connected
sjaiber-spark_1 | 2023-01-25T08:36:12.648698595Z 2023/01/25 09:36:12 INFO …lox_devcon_spark.connection HandshakeMessage(name=‘BREWBLOX’, firmware_version=‘10bb1f6d’, proto_version=‘9601ba60’, firmware_date=‘2023-01-06’, proto_date=‘2023-01-06’, system_version=‘3.2.0’, platform=‘p1’, reset_reason_hex=‘78’, reset_data_hex=‘00’, device_id=‘1E003A001147383531363134’, reset_reason=‘DFU_MODE’, reset_data=‘NOT_SPECIFIED’)
sjaiber-spark_1 | 2023-01-25T08:36:12.690281672Z 2023/01/25 09:36:12 INFO …ox_devcon_spark.block_store Read 6 blocks
sjaiber-spark_1 | 2023-01-25T08:36:12.711899914Z 2023/01/25 09:36:12 INFO …evcon_spark.synchronization System uptime: 6m47s
sjaiber-spark_1 | 2023-01-25T08:36:12.712361638Z 2023/01/25 09:36:12 INFO …evcon_spark.synchronization System updates per second: 14.828
sjaiber-spark_1 | 2023-01-25T08:36:14.005460406Z 2023/01/25 09:36:14 ERROR …evcon_spark.synchronization Sync subroutine failed: sync controller settings - CommandException(BLOCK_WRITE, INSUFFICIENT_STORAGE)
sjaiber-spark_1 | 2023-01-25T08:36:14.014458124Z 2023/01/25 09:36:14 ERROR …evcon_spark.synchronization Failed to sync: CommandException(BLOCK_WRITE, INSUFFICIENT_STORAGE)
sjaiber-spark_1 | 2023-01-25T08:36:14.014643804Z 2023/01/25 09:36:14 ERROR brewblox_service.repeater error during run(): CommandException(BLOCK_WRITE, INSUFFICIENT_STORAGE)
sjaiber-spark_1 | 2023-01-25T08:36:14.015387876Z 2023/01/25 09:36:14 INFO …lox_devcon_spark.connection <SparkConnection for /dev/ttyACM0> closed stream writer
sjaiber-spark_1 | 2023-01-25T08:36:14.019580585Z 2023/01/25 09:36:14 INFO …lox_devcon_spark.connection <SparkConnection for /dev/ttyACM0> terminated subprocess
sjaiber-spark_1 | 2023-01-25T08:36:14.019770848Z 2023/01/25 09:36:14 ERROR brewblox_service.repeater <SparkConnection for /dev/ttyACM0> error during run(): ConnectionError(EOF received)
sjaiber-spark_1 | 2023-01-25T08:36:14.019839963Z 2023/01/25 09:36:14 INFO …lox_devcon_spark.connection Retrying connection…
sjaiber-spark_1 | 2023-01-25T08:36:14.042659730Z 2023/01/25 09:36:14 INFO …_devcon_spark.service_store read {‘namespace’: ‘spark-service’, ‘id’: ‘sjaiber-spark-service-db’, ‘data’: {‘autoconnecting’: True, ‘retry_interval’: 2}}
sjaiber-spark_1 | 2023-01-25T08:36:14.070315444Z 2023/01/25 09:36:14 INFO …evcon_spark.synchronization Service temperature unit set to degC
sjaiber-spark_1 | 2023-01-25T08:36:16.023801297Z 2023/01/25 09:36:16 INFO …_devcon_spark.connect_funcs Discovering devices… (all)
sjaiber-spark_1 | 2023-01-25T08:36:16.058489652Z 2023/01/25 09:36:16 INFO …_devcon_spark.connect_funcs Discovered [‘/dev/ttyACM0’, ‘P1 - P1 Serial’, ‘USB VID:PID=2B04:C008 SER=1e003a001147383531363134 LOCATION=1-1.4:1.0’]
sjaiber-spark_1 | 2023-01-25T08:36:17.089243859Z 2023/01/25 09:36:17 INFO …lox_devcon_spark.connection <SparkConnection for /dev/ttyACM0> connected
sjaiber-spark_1 | 2023-01-25T08:36:17.097618444Z 2023/01/25 09:36:17 INFO …lox_devcon_spark.connection HandshakeMessage(name=‘BREWBLOX’, firmware_version=‘10bb1f6d’, proto_version=‘9601ba60’, firmware_date=‘2023-01-06’, proto_date=‘2023-01-06’, system_version=‘3.2.0’, platform=‘p1’, reset_reason_hex=‘78’, reset_data_hex=‘00’, device_id=‘1E003A001147383531363134’, reset_reason=‘DFU_MODE’, reset_data=‘NOT_SPECIFIED’)
sjaiber-spark_1 | 2023-01-25T08:36:17.139704860Z 2023/01/25 09:36:17 INFO …ox_devcon_spark.block_store Read 6 blocks
sjaiber-spark_1 | 2023-01-25T08:36:17.164585226Z 2023/01/25 09:36:17 INFO …evcon_spark.synchronization System uptime: 6m51s
sjaiber-spark_1 | 2023-01-25T08:36:17.165068253Z 2023/01/25 09:36:17 INFO …evcon_spark.synchronization System updates per second: 14.824
sjaiber-spark_1 | 2023-01-25T08:36:17.715174728Z 2023/01/25 09:36:17 INFO …ox_devcon_spark.block_store Saved 6 block(s)
sjaiber-spark_1 | 2023-01-25T08:36:18.451199330Z 2023/01/25 09:36:18 ERROR …evcon_spark.synchronization Sync subroutine failed: sync controller settings - CommandException(BLOCK_WRITE, INSUFFICIENT_STORAGE)
sjaiber-spark_1 | 2023-01-25T08:36:18.451528657Z 2023/01/25 09:36:18 ERROR …evcon_spark.synchronization Failed to sync: CommandException(BLOCK_WRITE, INSUFFICIENT_STORAGE)
sjaiber-spark_1 | 2023-01-25T08:36:18.452911382Z 2023/01/25 09:36:18 ERROR brewblox_service.repeater error during run(): CommandException(BLOCK_WRITE, INSUFFICIENT_STORAGE)
sjaiber-spark_1 | 2023-01-25T08:36:18.459809334Z 2023/01/25 09:36:18 INFO …lox_devcon_spark.connection <SparkConnection for /dev/ttyACM0> closed stream writer
sjaiber-spark_1 | 2023-01-25T08:36:18.460875389Z 2023/01/25 09:36:18 INFO …lox_devcon_spark.connection <SparkConnection for /dev/ttyACM0> terminated subprocess
sjaiber-spark_1 | 2023-01-25T08:36:18.462315251Z 2023/01/25 09:36:18 ERROR brewblox_service.repeater <SparkConnection for /dev/ttyACM0> error during run(): ConnectionError(EOF received)
sjaiber-spark_1 | 2023-01-25T08:36:18.463327868Z 2023/01/25 09:36:18 INFO …lox_devcon_spark.connection Retrying connection…
sjaiber-spark_1 | 2023-01-25T08:36:18.492871262Z 2023/01/25 09:36:18 INFO …_devcon_spark.service_store read {‘namespace’: ‘spark-service’, ‘id’: ‘sjaiber-spark-service-db’, ‘data’: {‘autoconnecting’: True, ‘retry_interval’: 2}}
sjaiber-spark_1 | 2023-01-25T08:36:18.519355815Z 2023/01/25 09:36:18 INFO …evcon_spark.synchronization Service temperature unit set to degC
sjaiber-spark_1 | 2023-01-25T08:36:20.468688074Z 2023/01/25 09:36:20 INFO …_devcon_spark.connect_funcs Discovering devices… (all)
sjaiber-spark_1 | 2023-01-25T08:36:20.504125396Z 2023/01/25 09:36:20 INFO …_devcon_spark.connect_funcs Discovered [‘/dev/ttyACM0’, ‘P1 - P1 Serial’, ‘USB VID:PID=2B04:C008 SER=1e003a001147383531363134 LOCATION=1-1.4:1.0’]
sjaiber-spark_1 | 2023-01-25T08:36:21.538130582Z 2023/01/25 09:36:21 INFO …lox_devcon_spark.connection <SparkConnection for /dev/ttyACM0> connected
sjaiber-spark_1 | 2023-01-25T08:36:21.571700381Z 2023/01/25 09:36:21 INFO …lox_devcon_spark.connection HandshakeMessage(name=‘BREWBLOX’, firmware_version=‘10bb1f6d’, proto_version=‘9601ba60’, firmware_date=‘2023-01-06’, proto_date=‘2023-01-06’, system_version=‘3.2.0’, platform=‘p1’, reset_reason_hex=‘78’, reset_data_hex=‘00’, device_id=‘1E003A001147383531363134’, reset_reason=‘DFU_MODE’, reset_data=‘NOT_SPECIFIED’)
sjaiber-spark_1 | 2023-01-25T08:36:21.616634958Z 2023/01/25 09:36:21 INFO …ox_devcon_spark.block_store Read 6 blocks
sjaiber-spark_1 | 2023-01-25T08:36:21.686249691Z 2023/01/25 09:36:21 INFO …evcon_spark.synchronization System uptime: 6m56s
sjaiber-spark_1 | 2023-01-25T08:36:21.686604852Z 2023/01/25 09:36:21 INFO …evcon_spark.synchronization System updates per second: 14.844
sjaiber-spark_1 | 2023-01-25T08:36:22.974896164Z 2023/01/25 09:36:22 ERROR …evcon_spark.synchronization Sync subroutine failed: sync controller settings - CommandException(BLOCK_WRITE, INSUFFICIENT_STORAGE)
sjaiber-spark_1 | 2023-01-25T08:36:22.980256544Z 2023/01/25 09:36:22 ERROR …evcon_spark.synchronization Failed to sync: CommandException(BLOCK_WRITE, INSUFFICIENT_STORAGE)
sjaiber-spark_1 | 2023-01-25T08:36:22.980464151Z 2023/01/25 09:36:22 ERROR brewblox_service.repeater error during run(): CommandException(BLOCK_WRITE, INSUFFICIENT_STORAGE)
sjaiber-spark_1 | 2023-01-25T08:36:22.984573786Z 2023/01/25 09:36:22 INFO …lox_devcon_spark.connection <SparkConnection for /dev/ttyACM0> closed stream writer
sjaiber-spark_1 | 2023-01-25T08:36:22.985251399Z 2023/01/25 09:36:22 INFO …lox_devcon_spark.connection <SparkConnection for /dev/ttyACM0> terminated subprocess
sjaiber-spark_1 | 2023-01-25T08:36:22.986542509Z 2023/01/25 09:36:22 ERROR brewblox_service.repeater <SparkConnection for /dev/ttyACM0> error during run(): ConnectionError(EOF received)
sjaiber-spark_1 | 2023-01-25T08:36:22.987553146Z 2023/01/25 09:36:22 INFO …lox_devcon_spark.connection Retrying connection…
sjaiber-spark_1 | 2023-01-25T08:36:23.013342274Z 2023/01/25 09:36:23 INFO …_devcon_spark.service_store read {‘namespace’: ‘spark-service’, ‘id’: ‘sjaiber-spark-service-db’, ‘data’: {‘autoconnecting’: True, ‘retry_interval’: 2}}
sjaiber-spark_1 | 2023-01-25T08:36:23.042288473Z 2023/01/25 09:36:23 INFO …evcon_spark.synchronization Service temperature unit set to degC
sjaiber-spark_1 | 2023-01-25T08:36:24.991548387Z 2023/01/25 09:36:24 INFO …_devcon_spark.connect_funcs Discovering devices… (all)
sjaiber-spark_1 | 2023-01-25T08:36:25.025566160Z 2023/01/25 09:36:25 INFO …_devcon_spark.connect_funcs Discovered [‘/dev/ttyACM0’, ‘P1 - P1 Serial’, ‘USB VID:PID=2B04:C008 SER=1e003a001147383531363134 LOCATION=1-1.4:1.0’]
sjaiber-spark_1 | 2023-01-25T08:36:26.054710660Z 2023/01/25 09:36:26 INFO …lox_devcon_spark.connection <SparkConnection for /dev/ttyACM0> connected
sjaiber-spark_1 | 2023-01-25T08:36:26.069519232Z 2023/01/25 09:36:26 INFO …lox_devcon_spark.connection HandshakeMessage(name=‘BREWBLOX’, firmware_version=‘10bb1f6d’, proto_version=‘9601ba60’, firmware_date=‘2023-01-06’, proto_date=‘2023-01-06’, system_version=‘3.2.0’, platform=‘p1’, reset_reason_hex=‘78’, reset_data_hex=‘00’, device_id=‘1E003A001147383531363134’, reset_reason=‘DFU_MODE’, reset_data=‘NOT_SPECIFIED’)
sjaiber-spark_1 | 2023-01-25T08:36:26.111202779Z 2023/01/25 09:36:26 INFO …ox_devcon_spark.block_store Read 6 blocks
sjaiber-spark_1 | 2023-01-25T08:36:26.132711488Z 2023/01/25 09:36:26 INFO …evcon_spark.synchronization System uptime: 7m
sjaiber-spark_1 | 2023-01-25T08:36:26.133291547Z 2023/01/25 09:36:26 INFO …evcon_spark.synchronization System updates per second: 14.809
sjaiber-spark_1 | 2023-01-25T08:36:26.654575522Z 2023/01/25 09:36:26 INFO …ox_devcon_spark.block_store Saved 6 block(s)
sjaiber-spark_1 | 2023-01-25T08:36:27.426636569Z 2023/01/25 09:36:27 ERROR …evcon_spark.synchronization Sync subroutine failed: sync controller settings - CommandException(BLOCK_WRITE, INSUFFICIENT_STORAGE)
sjaiber-spark_1 | 2023-01-25T08:36:27.427502673Z 2023/01/25 09:36:27 ERROR …evcon_spark.synchronization Failed to sync: CommandException(BLOCK_WRITE, INSUFFICIENT_STORAGE)
sjaiber-spark_1 | 2023-01-25T08:36:27.429245977Z 2023/01/25 09:36:27 ERROR brewblox_service.repeater error during run(): CommandException(BLOCK_WRITE, INSUFFICIENT_STORAGE)
sjaiber-spark_1 | 2023-01-25T08:36:27.438449635Z 2023/01/25 09:36:27 INFO …lox_devcon_spark.connection <SparkConnection for /dev/ttyACM0> closed stream writer
sjaiber-spark_1 | 2023-01-25T08:36:27.438690835Z 2023/01/25 09:36:27 INFO …lox_devcon_spark.connection <SparkConnection for /dev/ttyACM0> terminated subprocess
sjaiber-spark_1 | 2023-01-25T08:36:27.439097403Z 2023/01/25 09:36:27 ERROR brewblox_service.repeater <SparkConnection for /dev/ttyACM0> error during run(): ConnectionError(EOF received)
sjaiber-spark_1 | 2023-01-25T08:36:27.440788258Z 2023/01/25 09:36:27 INFO …lox_devcon_spark.connection Retrying connection…
sjaiber-spark_1 | 2023-01-25T08:36:27.464439390Z 2023/01/25 09:36:27 INFO …_devcon_spark.service_store read {‘namespace’: ‘spark-service’, ‘id’: ‘sjaiber-spark-service-db’, ‘data’: {‘autoconnecting’: True, ‘retry_interval’: 2}}
sjaiber-spark_1 | 2023-01-25T08:36:27.493901428Z 2023/01/25 09:36:27 INFO …evcon_spark.synchronization Service temperature unit set to degC
sjaiber-spark_1 | 2023-01-25T08:36:29.444591204Z 2023/01/25 09:36:29 INFO …_devcon_spark.connect_funcs Discovering devices… (all)
sjaiber-spark_1 | 2023-01-25T08:36:29.480587909Z 2023/01/25 09:36:29 INFO …_devcon_spark.connect_funcs Discovered [‘/dev/ttyACM0’, ‘P1 - P1 Serial’, ‘USB VID:PID=2B04:C008 SER=1e003a001147383531363134 LOCATION=1-1.4:1.0’]
sjaiber-spark_1 | 2023-01-25T08:36:30.514851379Z 2023/01/25 09:36:30 INFO …lox_devcon_spark.connection <SparkConnection for /dev/ttyACM0> connected
sjaiber-spark_1 | 2023-01-25T08:36:30.520843121Z 2023/01/25 09:36:30 INFO …lox_devcon_spark.connection HandshakeMessage(name=‘BREWBLOX’, firmware_version=‘10bb1f6d’, proto_version=‘9601ba60’, firmware_date=‘2023-01-06’, proto_date=‘2023-01-06’, system_version=‘3.2.0’, platform=‘p1’, reset_reason_hex=‘78’, reset_data_hex=‘00’, device_id=‘1E003A001147383531363134’, reset_reason=‘DFU_MODE’, reset_data=‘NOT_SPECIFIED’)
sjaiber-spark_1 | 2023-01-25T08:36:30.560717531Z 2023/01/25 09:36:30 INFO …ox_devcon_spark.block_store Read 6 blocks
sjaiber-spark_1 | 2023-01-25T08:36:30.585933735Z 2023/01/25 09:36:30 INFO …evcon_spark.synchronization System uptime: 7m5s
sjaiber-spark_1 | 2023-01-25T08:36:30.586576138Z 2023/01/25 09:36:30 INFO …evcon_spark.synchronization System updates per second: 14.824
sjaiber-spark_1 | 2023-01-25T08:36:31.875511000Z 2023/01/25 09:36:31 ERROR …evcon_spark.synchronization Sync subroutine failed: sync controller settings - CommandException(BLOCK_WRITE, INSUFFICIENT_STORAGE)
sjaiber-spark_1 | 2023-01-25T08:36:31.876517523Z 2023/01/25 09:36:31 ERROR …evcon_spark.synchronization Failed to sync: CommandException(BLOCK_WRITE, INSUFFICIENT_STORAGE)
sjaiber-spark_1 | 2023-01-25T08:36:31.880484969Z 2023/01/25 09:36:31 ERROR brewblox_service.repeater error during run(): CommandException(BLOCK_WRITE, INSUFFICIENT_STORAGE)
sjaiber-spark_1 | 2023-01-25T08:36:31.885513678Z 2023/01/25 09:36:31 INFO …lox_devcon_spark.connection <SparkConnection for /dev/ttyACM0> closed stream writer
sjaiber-spark_1 | 2023-01-25T08:36:31.886938071Z 2023/01/25 09:36:31 INFO …lox_devcon_spark.connection <SparkConnection for /dev/ttyACM0> terminated subprocess
sjaiber-spark_1 | 2023-01-25T08:36:31.889059869Z 2023/01/25 09:36:31 ERROR brewblox_service.repeater <SparkConnection for /dev/ttyACM0> error during run(): ConnectionError(EOF received)
sjaiber-spark_1 | 2023-01-25T08:36:31.891446045Z 2023/01/25 09:36:31 INFO …lox_devcon_spark.connection Retrying connection…
sjaiber-spark_1 | 2023-01-25T08:36:31.916615686Z 2023/01/25 09:36:31 INFO …_devcon_spark.service_store read {‘namespace’: ‘spark-service’, ‘id’: ‘sjaiber-spark-service-db’, ‘data’: {‘autoconnecting’: True, ‘retry_interval’: 2}}
sjaiber-spark_1 | 2023-01-25T08:36:31.949907356Z 2023/01/25 09:36:31 INFO …evcon_spark.synchronization Service temperature unit set to degC
sjaiber-spark_1 | 2023-01-25T08:36:33.894662109Z 2023/01/25 09:36:33 INFO …_devcon_spark.connect_funcs Discovering devices… (all)
sjaiber-spark_1 | 2023-01-25T08:36:33.928596496Z 2023/01/25 09:36:33 INFO …_devcon_spark.connect_funcs Discovered [‘/dev/ttyACM0’, ‘P1 - P1 Serial’, 'USB
Hope you can help
Regards
-Per
