OK Finally got around to doing this. First, I changed out the Raspberry Pi 3 to one that says “Made in the UK”!
Got everything back up and running. Ran the brewpi updater with the Script not running, and received this:
You are on branch master
The latest commit in /home/brewpi is 67efcb0e40f0be4b40ad1e7cd207eedcf0dd032c o n Wed, 27 Apr 2016 18:25:10
The latest commit on origin/master is 67efcb0e40f0be4b40ad1e7cd207eedcf0dd032c o n Wed, 27 Apr 2016 18:25:10
The path ‘/var/www’ does not seem to be a valid git repository
What path did you install the BrewPi web interface scripts to? /var/www/html
The latest commit in /var/www/html is 1e0778703edbbd3ef33072ba0b260c491fba90cc o n Mon, 11 Jan 2016 13:04:54
The latest commit on origin/master is 1e0778703edbbd3ef33072ba0b260c491fba90cc o n Mon, 11 Jan 2016 13:04:54
Your local version of /var/www/html is up to date!
The update script can automatically check your controller firmware version and program it with the latest release on GitHub, would you like to do this now? [Y/n ]:y
Oct 28 2016 11:31:02 Opening serial port
JSON decode error: Unterminated string starting at: line 1 column 18 (char 17)
Could not parse version number: {“v”:“0.4.3”,“n”:"0.4.3-0-g4d
JSON decode error: Expecting ‘,’ delimiter or ‘}’: line 1 column 42 (char 41)
Could not parse version number: {“v”:“0.4.3”,“n”:“0.4.3-0-g4d00879”,“s”:4
JSON decode error: Unterminated string starting at: line 1 column 37 (char 36)
Could not parse version number: {“v”:“0.4.3”,“n”:“0.4.3-0-g4d00879”,"s
JSON decode error: Unterminated string starting at: line 1 column 49 (char 48)
Could not parse version number: {“v”:“0.4.3”,“n”:“0.4.3-0-g4d00879”,“s”:4,“y”:0, "b
JSON decode error: Expecting value: line 1 column 53 (char 52)
Could not parse version number: {“v”:“0.4.3”,“n”:“0.4.3-0-g4d00879”,“s”:4,“y”:0, “b”:
Could not parse version number: {“v”:“0.4.3”,“n”:"0.4.3-0-g4d00879
JSON decode error: Expecting ‘,’ delimiter or ‘}’: line 1 column 13 (char 12)
Could not parse version number: {“v”:"0.4.3"
Found BrewPi v0.0.0 on port /dev/ttyACM0
Current firmware version on controller: 0.0.0
No compatible releases found for None None
WTF??? Obviously I am doing something wrong???
