Web based Chart Scale
I upgraded the software / firmware on my Brewpi Spark 2 today, and the Temperature Scale has gone astray and shows a range down to -130 Deg C as follows:-
Therefore, is there a way of re-setting the chart to be a viewable scale?
Thanks.
This scaling is caused by a single data point that seems to be at -120.
If you remove that data point, you’re scale will be normal again.
You can do that by editing the JSON file containing the data point in /var/www/html/data/Juicy%20bits/
Thanks Elco, much appreciated as that worked.
