Accessing the Web Interface
I had my brewpi working previously and then moved across the country. New router… new settings. I reconfigured the brewpi from scratch, but have not been successful accessing the web interface.
This is what I am using in /etc/network/interfaces file:
address 192.168.1.63
netmask 255.255.255.0
gateway 192.168.1.254
My router configuration looks like this:
Private LAN IP Address 192.168.1.254
Private LAN Subnet Mask 255.255.255.0
DHCP Start IP Address 192.168.1.64
DHCP End IP Address 192.168.1.253
When I run ip route show I get this:
pi@brewpi:~ $ ip route show
default via 192.168.1.254 dev eth0 metric 202
192.168.1.0/24 dev eth0 proto kernel scope link src 192.168.1.190 metric 202
and ifconfig produces this:
pi@brewpi:~ $ ifconfig
eth0 Link encap:Ethernet HWaddr b8:27:eb:6a:ee:f0
      inet addr:192.168.1.190  Bcast:192.168.1.255  Mask:255.255.255.0
      inet6 addr: fe80::2c8e:570f:78bc:872c/64 Scope:Link
      inet6 addr: 2602:306:25a0:a1e9:d316:478c:339e:fa15/64 Scope:Global
      UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
lo Link encap:Local Loopback
      inet addr:127.0.0.1  Mask:255.0.0.0
      inet6 addr: ::1/128 Scope:Host
      UP LOOPBACK RUNNING  MTU:65536  Metric:1
When I go to the browser and enter 192.168.1.63, I get:
This webpage is not available
ERR_CONNECTION_TIMED_OUT
If I instead enter 192.168.1.190 into the browser, I get:
Not Found
The requested URL / was not found on this server.
Apache/2.4.10 (Raspbian) Server at 192.168.1.190 Port 80
Am I misreading the instructions? I thought .63 would be in the “safe zone” but it doesn’t seem to be recognized.
Thank you for the help,
Dean
Notice the DHCP start range .64 so .63 should never get handed out. Also it looks like you have your Pi hard wired since I see no wlan interface in your ifconfig (I usually tell people to use the -a flag with ifconfig just so you get a lot of detail).
I highly suggest unless you really understand how the networking works in a *NIX system you keep it simple. Setup the interface you wish to use as just plain old DHCP and then setup a MAC reservation in the router for that interface in the useable range. This will let the Pi always get the same address and save you some sanity. I even follow this in my setup and I have been a *NIX guy for many many moons.
Ok so now onto your web interface issue. From the error you got it just looks like you don’t have the content loaded, now this is probably due to the updates made in the Apache distro which points the default HTML dir to a different location. I don’t recall exactly where it points but there are post on this forum about it (also you can search the conf file for DocumentRoot and figure things out).
I hope this helps out.
Cheers,
-Stephen
I found it here:
That worked perfectly. Thank you very much!!
