BrewBlox Basic questions
Hi
I have been running a brewpi spark for some time now (awesome product by the way) I have finally found BrewBlox (there should really be a link on the old brewpi site :wink: ) And I cant wait to start expanding my system. but there is three questions i don’t seem to find a good answer for:
  1. Is the “spark” referenced in the documentation the “brewpi spark 3”?
  2. If so does the “brewpi spark 3” require new firmware?
  3. And most important: do you require 1 “brewpi spark 3”/spark for each setup? Meaning if you are to run 2 converted fridges and one 3 kettle brewing setup. How many sparks would you need?
Bjørn
It is a software update for the Spark. You can flash it as part of the install process. I do recommend a fresh raspbian install.
With the BrewBlox firmware the Spark can control multiple processes.
A BrewBlox server (the pi) can serve multiple sparks. You could opt to use a separate spark for fermentation and for mashing to keep your cables shorter and your processes somewhat independent.
Tanks for a quick reply…
Just to start working on my next shopping list then:)
Hi Elco,
I am at the end of Brewblox installation but not sure what to respond to the setup questions under Step 5 in the Getting started guide. Please advise?
BR Ken
Before you run setup, navigate to the install dir (default brewblox, so cd brewblox)
Hi Bob,
It looks likes that Brewblox directory is not created since I got the error as shown below
BR Ken
Have you done brewblox-ctl install first?
I did the installation with the following input
And for some reason, I still got the error
BR Ken
If you run ls, it will show the directories. A brewblox one should be among them.
Hi Bob
It seems that only pi directory have been created since ls command just shows
BR Ken
Out of curiosity, try ls -a in the pi home directory. I wonder if it stripped the “/” from “./BrewBlox” (which would make it a hidden directory).
If this is the case, you should be able to unhide it with mv .BrewBlox BrewBlox.
I have tried to run the “brewblox-ctl install” command once more with the same result as shown below.
At the end of the execution, errors occur.
BR Ken
It seems like brewblox-ctl install exited with an error before it created the directory.
To fix this, you could try to reboot your raspberry, and then run the following commands:
curl -fsSL https://get.docker.com -o get-docker.sh
sudo sh get-docker.sh
brewblox-ctl setup
Linux is case sensitive…
Hi Bob,
I have tried to run the commands. During execution of the last commend I got the following question. What should be replied to this question?
BR Ken
My bad on that one: you should navigate to your install dir before running brewblox-ctl setup.
Did your brewblox-ctl install complete without errors this time? Can you see your install directory if you run ls -a?
Running ls -a shows
and cd ./brewblox shows
Means that something goes wrong during installation?
BR Ken
Did you reboot your raspberry?
Did your install command finish successfully?
What was the output of the install command?
The installation is executed after cold boot and output is shown below
     sudo apt update
     sudo apt upgrade -y
     sudo apt install -y libssl-dev libffi-dev
     curl -sSL https://get.docker.com | sh
     sudo usermod -aG docker $USER
     sudo /usr/bin/python3 -m pip install -U docker-compose
     mkdir -p ./brewblox
     touch ./brewblox/.env
     /usr/bin/python3 -m dotenv.cli --quote never -f ./brewblox/.env set BRE                                                       WBLOX_RELEASE edge
     /usr/bin/python3 -m dotenv.cli --quote never -f ./brewblox/.env set BRE                                                       WBLOX_CFG_VERSION 0.0.0
     sudo reboot
Running command:
sudo apt update
Get:1 http://archive.raspberrypi.org/debian stretch InRelease [25.4 kB]
Get:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease [15.0 kB]
Hit:3 https://download.docker.com/linux/raspbian stretch InRelease
Err:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease
The following signatures couldn’t be verified because the public key is not av ailable: NO_PUBKEY 9165938D90FDDD2E
Err:1 http://archive.raspberrypi.org/debian stretch InRelease
The following signatures couldn’t be verified because the public key is not av ailable: NO_PUBKEY 82B129927FA3303E
Fetched 40.3 kB in 2s (16.9 kB/s)
Reading package lists… Done
Building dependency tree
All packages are up to date.
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG erverified because the public key is not available: NO_PUBKEY 9165938D90FDDD2E
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG erified because the public key is not available: NO_PUBKEY 82B129927FA3303E
W: Failed to fetch http://raspbian.raspberrypi.org/raspbian/dists/stretch/InRelease The following signatures couldn’t be verified beca
W: Failed to fetch http://archive.raspberrypi.org/debian/dists/stretch/InRelease The following signatures couldn’t be verified because
W: Some index files failed to download. They have been ignored, or old ones used instead.
Running command:
sudo apt upgrade -y
Calculating upgrade… Done
Running command:
libffi-dev is already the newest version (3.2.1-6).
libssl-dev is already the newest version (1.1.0j-1~deb9u1).
Running command:
Executing docker install script, commit: 2f4ae48
  • sudo -E sh -c apt-get update -qq >/dev/null
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://raspbian.raspberrypi.org/raspbian stretch InRelease: The following signatures could n’t be verified because the public key is not available: NO_PUBKEY 9165938D90FDDD2E
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://archive.raspberrypi.org/debian stretch InRelease: The following signatures couldn’t be verified because the public key is not available: NO_PUBKEY 82B129927FA3303E
    W: Failed to fetch http://raspbian.raspberrypi.org/raspbian/dists/stretch/InRelease The following signatures could n’t be verified because the public key is not available: NO_PUBKEY 9165938D90FDDD2E
    W: Failed to fetch http://archive.raspberrypi.org/debian/dists/stretch/InRelease The following signatures couldn’t be verified because the public key is not available: NO_PUBKEY 82B129927FA3303E
  • sudo -E sh -c apt-get install -y -qq apt-transport-https ca-certificates curl >/dev/null
  • sudo -E sh -c curl -fsSL “https://download.docker.com/linux/raspbian/gpg” | apt-key add -qq - >/dev/null
    Warning: apt-key output should not be parsed (stdout is not a terminal)
  • sudo -E sh -c echo “deb [arch=armhf] https://download.docker.com/linux/raspbian stretch stable” > /etc/apt/source s.list.d/docker.list
  • [ -n ]
  • sudo -E sh -c apt-get install -y -qq --no-install-recommends docker-ce >/dev/null
    E: Unable to locate package docker-ce
Error: Command ‘curl -sSL https://get.docker.com | sh’ returned non-zero exit status 100
Thank you. If your install command output ends with “error: XXXX”, you shouldn’t continue running commands: it means something went wrong that must be solved first.
It appears this specific issue is in the Raspberry Pi itself, not in BrewBlox.
A google search indicates a possible solution:
wget http://archive.raspbian.org/raspbian.public.key -O - | sudo apt-key add -
If this still ends in an error, you may have a corrupted SD card. In that case it’s best to restart the install guide from the beginning.
