Relevant links:
- User guides: https://brewblox.netlify.app/
- Discord server: Brewblox
- Previous release notes: Brewblox release notes | Brewblox
- Project board: BrewBlox · GitHub
- Code repositories: BrewBlox · GitHub
Brewblox release 2021/11/29
firmware release date: 2021-11-29
On the firmware side of things, we have made progress hunting down the bug that causes hangups on the Spark 2/3. We’re still having problems consistently reproducing it, but have narrowed down the scope, and identified a likely fix.
The problem appears to be triggered by Wifi disconnects. This includes the router stopping or restarting, but also channel and repeater changes.
We improved the code that handles Wifi disconnects. The immediate effect is that the Spark no longer requires a fixed Wifi channel, but we’re not sure whether this resolves all hangups. Please let us know if you continue to experience them.
Apart from firmware bug hunts, we have also reworked the Tilt service to support custom and unique device names.
Previously, if multiple Tilt devices of the same color were detected, their data would be arbitrarily mixed.
Now, a unique name is generated for every Tilt. The default name is still the color, but after the first, it will increment the name.
For example, if you have three red Tilts, you will end up with the device names Red, Red-2, and Red-3. You can set custom device names for all Tilts in the UI.
Existing calibration files are compatible with the first generated name. If you only have a single Tilt, you do not need to make changes.
The field names in the Tilt history data have changed. You will need to update the used fields in Graph widgets.
Temperature[degF]
/Temperature[degC]
→temperature[degF]
/temperature[degC]
Specific gravity
→specificGravity
Plato[degP]
→plato[degP]
Before, the Calibrated temperature
and Calibrated specific gravity
fields would be added if calibration data was present. Now, if calibration data is present, the default fields (temperature
, specificGravity
, plato
) will show calibrated data, and the uncalibratedTemperature
/ uncalibratedSpecificGravity
/ uncalibratedPlato
fields are added to show raw data.
The UI now also supports setting a preferred unit for Specific Gravity values: unitless Specific Gravity, or degrees Plato. The new Display: Tilt Builder part will show temperature and gravity in the preferred units. Values for all units are still included in history data.
For a comprehensive overview of changes, see Update spec for Tilt events to include unique addressing and improved property names · Issue #2 · BrewBlox/brewblox-tilt · GitHub.
For setup and calibration instructions, see GitHub - BrewBlox/brewblox-tilt: Brewblox service for the Tilt hydrometer.
Note: if Tilt data does not show up in the UI after updating, you may still be using the original third-party Tilt service. To fix this, run brewblox-ctl add-tilt -f
Changes:
- (feature) The Tilt service now generates unique names if multiple devices with the same color are detected.
- (feature) The Tilt service now supports custom device names.
- (feature) Added the Steam Condenser Builder part.
- (feature) Added the Tilt Display Builder part.
- (feature) Added Ground and Power Only channel types to the OneWire GPIO Module editor.
- (feature) The last used action in Quick Actions is now highlighted.
- (feature) Updated field names in history data published by the Tilt service.
- (feature) Preferred Specific Gravity units are now configurable in the admin page. The choices are SG and Plato.
- (feature) Blank lines and comments in
docker-compose.yml
will no longer be overwritten duringbrewblox-ctl update
. - (feature) Added the
brewblox-ctl termbin {FILE}
command. This generates a shareable termbin.com URL for a given text file (as used inbrewblox-ctl log
). - (feature) Services and dashboards can now be hidden from view in the sidebar. You can toggle this setting in the admin page.
- (improve) brewblox-ctl will now explicitly disable IPv6 in avahi daemon configuration.
- (improve) brewblox-ctl no longer depends on
nc
being installed system-wide. This helps with runningbrewblox-ctl log
on Synology systems. - (improve) The brewblox install script lists required Apt packages if
apt-get
is not detected. - (improve) brewblox-ctl no longer depends on
netstat
being installed system-wide. - (improve) Removed
tio
andnet-tools
from installed apt packages. - (improve)
brewblox-ctl http {METHOD} {URL} --pretty
now generates valid JSON. - (improve) Generated mounted volumes in
docker-compose.yml
anddocker-compose.shared.yml
now use the more explicit syntax. - (improve) Tilt data is now included when running
brewblox-ctl backup save
. - (improve) Renamed
brewblox-ctl fix avahi-reflection
tobrewblox-ctl fix avahi
. - (improve) The Tilt service now waits on startup until a Bluetooth dongle or chip is detected on the host.
- (fix) Resolved firmware hangups in the Spark 2/3 when the Wifi access point switches channels.
- (fix) Fixed a bug when importing a Builder layout that references a non-existent Spark service.
- (fix) Service overrides in
docker-compose.yml
that do not have aimage
field do no longer cause Spark discovery to crash. - (fix)
brewblox-ctl
and the brewblox install script now useapt-get
instead ofapt
to avoid conflicts on MacOS. - (fix)
brewblox-ctl wifi
now correctly usespyserial-miniterm
instead ofminiterm.py
. Same program, different name. - (fix) Tilt Bluetooth events no longer get drowned out by other non-Tilt Bluetooth Low Energy devices.
