I think you missed the dot on step 3 of the installation.
Right you are! Thanks!
Does this work with legacy branch?
I couldnāt tell you, I havenāt done anything with the legacy branch.
Iām running Legacy and could test it out when you have an Android version.
Just purchased the app before reading all the way to the end of the topic. Iām running the legacy software with sbowlerās Tilt integration so I guess Iāll be testing it out!
Just installed the API on my (legacy) brewpi and it looks like itās working as advertised. Thanks to @nickhough for a cool app and easy installation!
Cool stuff going on here! @Elco How are things with the new front end? Are you still going with Quasar? I havenāt got any experience with that but Iāve tried out bunch of other āsingle codebase / cross platformā frameworks. Seems like a sensible way to go to me.
@nickhough So to clarify the App, works on iOS and will continue to support the new BrewPi api that @Elco is working on, that should be close to done in 2-3 months from what I last heard? Assuming that is true, will that app be able to remotely access the Brewpi when not on a local network if I wanted to check status on my fermenters when not at home? Will it have the same functions/capabilities as the brewpi interface for configuring or is it intended for just monitoring/logging etc? TIA
No, thatās not correct. The app Iāve built has no integration with the official BrewPi API - as there wasnāt one when I built this app.
As far as functionality, as of right now itās read only. When the API is released, Iāll review and go from there.
