Yes I have run the latest updater, see below:
pi@raspberrypi ~ $ sudo python ~/brewpi-tools/updater.py
Most users will want to select the ‘master’ choice at each of the following menus.
Press enter to continue…
You are currently on branch master
Available branches on the remote ‘origin’ for /home/brewpi:
[0] develop
[1] master
[2] Skip updating this repository
Enter the number of the branch you wish to update [master]:
Keeping current branch master
The latest commit in /home/brewpi is aa3735c3a6ecabe3b04abacd35789226b80fba34 on Thu, 12 Mar 2015 00:29:23
The latest commit on origin/master is aa3735c3a6ecabe3b04abacd35789226b80fba34 on Thu, 12 Mar 2015 00:29:23
Available branches on the remote ‘origin’ for /var/www:
[0] develop
[1] master
The latest commit in /var/www is d44c03e786d0bde0dc43f86a8bd655659f3f3d2b on Wed, 11 Mar 2015 21:59:39
The latest commit on origin/master is d44c03e786d0bde0dc43f86a8bd655659f3f3d2b on Wed, 11 Mar 2015 21:59:39
The update script can automatically check your Arduino version and program it with the latest hex file from the BrewPi server, would you like to do this now? [Y/n]:n
Skipping Arduino update
*** Done updating BrewPi! ***
After this I ran the runafterupdate.sh
pi@raspberrypi ~ $ sudo /home/brewpi/utils/runAfterUpdate.sh
Reading package lists… Done
Building dependency tree
apache2 is already the newest version.
arduino-core is already the newest version.
git-core is already the newest version.
libapache2-mod-php5 is already the newest version.
php5-cgi is already the newest version.
php5-cli is already the newest version.
php5-common is already the newest version.
python-configobj is already the newest version.
python-git is already the newest version.
python-psutil is already the newest version.
python-serial is already the newest version.
python-simplejson is already the newest version.
rpi-update is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 21 not upgraded.
***** Done processing BrewPi dependencies *****
***** Updating cron for the brewpi user… *****
no crontab for brewpi
Checking entry for brewpi …
Done checking entry brewpi …
Checking entry for wifichecker …
Done checking entry wifichecker …
Restarting cron
[…] Restarting periodic command scheduler: cron[…] Stopping periodic comma[ ok heduler: cron.
[ ok ] Starting periodic command scheduler: cron.
After a reboot etc still no joy and the same errors as above if I try to run the script through the terminal.
