Hi all,
For the last couple of days me and a friend have been struggling with the setup of the brewpi controller. Long story short, we cannot seem to download the specified .hex-file to our Arduino board.
For reference, this is what we have done so far:
We set up our Raspberry Pi v2 to run as a headless computer with a running VNC server to display the RPi display over a WiFi connection. Furthermore, we ran all the update commands on the RPi command line (sudo apt-get update, sudo apt-get upgrade and so on).
Hooked up the RPi with an Arduino Micro board (which should be equal to Leonardo?). This is a working Arduino which currently runs the ‘blink’ program without any problems.
Then we ran the automatic installation script to install brewpi, which seemed to install smoothly without any fuzz. We got the web interface up and running and… then we got stuck.
As we get to understand from the http://docs.brewpi.com/after-install/program-arduino.html, the next step is to download a .hex configuration file to the Arduino board. Now, the docs says that the brewpi.py script should be up and running before this is done. Problem is, we can’t get it to run. The web interface says ‘script not running’, and nothing happens when we click the Start Script-button. Trying to run the script manually from the command line yields the following output before it just hangs
Oct 06 2015 20:39:14 Opening serial port
Oct 06 2015 20:39:14 Notification: Script started for beer 'My First BrewPi Run’
Oct 06 2015 20:39:24 Checking software version on controller…
It never snaps out of this state. Exactly the same output is shown in the web terminal thingy when we try to download the .hex file without running the script.
Browsing around on this forum told us to run the programArduinoFirstTime.py. That yields the following
Settings will not be restored
Devices will not be restored
Oct 06 2015 20:48:26 Opening serial port
before it hangs. Seems like it gets stuck in a loop somewhere while checking the SW version. Perhaps it can’t read from the serial port? BTW the serial ports should also be good as our USB port uses the default ttyACM0.
Finally, we tried running the ~/brewpi-tools/updater.py which yielded the following
[Errno 2] No such file or directory
Could not connect to socket of BrewPi process, maybe it just started and is not listening yet.
Could not send quit message to BrewPi instance with pid 6294!
Killing it instead!
SIGKILL sent to BrewPi instance with pid 6294!
You are on branch master
The latest commit in /home/brewpi is 4c7dfa342d8403eb2b485e9970e2cdec9e53c9e4 on Wed, 05 Aug 2015 23:15:44
The latest commit on origin/master is 4c7dfa342d8403eb2b485e9970e2cdec9e53c9e4 on Wed, 05 Aug 2015 23:15:44
The latest commit in /var/www is d44c03e786d0bde0dc43f86a8bd655659f3f3d2b on Wed, 11 Mar 2015 22:59:39
The latest commit on origin/master is d44c03e786d0bde0dc43f86a8bd655659f3f3d2b on Wed, 11 Mar 2015 22:59:39
Could not send quit message to BrewPi instance with pid 6295!
Killing it instead!
SIGKILL sent to BrewPi instance with pid 6295!
Oct 06 2015 20:45:07 Opening serial port
The weird thing is that no other forum posts we’ve seen shows a problem where the scripts hangs at that particular place. They all seem to get further and at least show a leading error message.
Best guess from our side is that there are issues with the serial port readings, but we have no clue as to how to go about and fix it. It would be much appreciated if some of you guys could lead us to the problem. I’m sure we’ve missed something somewhere.
Thanks in advance
Edit: one last thing: The wifichecker thing of the cron job keeps spamming us with the following error message in the web terminal window
/home/brewpi/utils/wifiChecker.sh: line 32: [: 192.168.10.1: binary operator expected
BrewPi: wifiChecker: Attempt 1 to reach 192.168.10.1
192.168.10.1 failed (Sun Oct 4 19:50:11 CEST 2015)
BrewPi: wifiChecker: Attempt 2 to reach 192.168.10.1
192.168.10.1 failed (Sun Oct 4 19:50:36 CEST 2015)
BrewPi: wifiChecker: Unable to reach router. Restarting wlan0 interface… (Sun Oct 4 19:51:01 CEST 2015)
Don’t now why this is complaining, as the WiFi seems to be up and running. Anyway, this turned out to be a long post, hope you guys take your time to read
