The error above is something that comes on when viewing the web interface for 5 seconds and then changes to my temps along with “Script Running” for 5 seconds and then back and forth it goes in a loop.
I have a Raspberry 3 and the Spark connected via USB with the Raspberry plug into an outlet. I did need to start with an image of Raspberry instead of NOOBs due to not being able to get my cardreader working right with NOOBs. I have updated the Raspberry PI to latest versions, updated BrewPi to latest version (I think .42 or .43 whichever is in the master). I am using wifi on the Pi to connect to my network. I have tried disabling the wifi checker and it did not work. I have also tried rerunning the permission commands in the setup guide (for version .30) and it still errors out then begins again.
One note for the Spark, I did try to connect the Photon to my router through a particle app on my iPhone by putting it in setup mode and connecting through the iPhone app. It never finished connecting and that’s when I assumed it wasn’t enabled yet. I was originally going to connect it to my Windows computer through WIFI but gave up. Then I went the Raspberry Pi route.
Any help in troubleshooting would be great. I have read from searching for this error but either it looked like they couldn’t get the script to run at all or the solution didn’t seem to work. (or I am enough of an idiot to not understand - which is likely.) Lastly, I am pretty new to the Pi, Linux and BrewPi.
