Hello I’am using BrewPi Spark 3 with glycol chiller, SS brew tech FTS pump and jacketed 30 liter canonical.
I use controller settings suggested by you in this post New Setup for Glycol Tank + Pump.
There’s a thread on glycol settings already. I’m camping and on my phone, so forgive me for not looking it up.
You’ll want to set beer-to-fridge to all zeros. You’ll want to set the cooler pwm period to 60 seconds and adjust Kp for your situation. Also reduce the minimum cooling time to a few seconds. It is key to limit running the pump to just a few seconds at a time. The glycol cools really quickly and it can take a while for the temperature change to reach the sensor.
It might even be needed to use a period of 600 seconds with a Kp of for example 4. So that with a temperature difference of 0.5 the pump and will run for ( 4 * 0.5 / 100 ) * 600 = 12 seconds every 10 minutes.
Also I see strange behavior, looks like bug to me. Brew pi turning cooler every minute even if beer temperature is lower then set point, also I don’t see those cooling cycles in web interface.
I run Spark 3 frimware v0.5.2 build 0.5.2-0-g72e633171.
