I am trying to set up a brewpi to work with my Raspberry 3. I got to loading the Portainer web interface. I can’t find the interface. Can you elaborate on where to find the interface? Do I type the IP address into the Hypriot command line?
Thanks for your help, I better with the hardware part then the coding part
Hi Elco
I had an issue with the SD card used for BrewPi running on Raspberry PI 3 and need to reinstall the system. I tried to use the portainer, but cannot deploy the portainer since the statement below cannot be executed. What should replace --name in the
Statement:
–name portainer portainer/portainer -H unix:///var/run/docker.sock
Shouldn’t the portainer be created with a name like the following
$ docker volume create portainer_data
Hi Elco
Thanks for your reply. I was not aware of that the entire statement must be executed as one string. I have successfully created the containers as shown below, even the published ports look’s a bit different than as shown in wiki.brewpi.com. Does it look correct?
that looks correct. I have not taken a new screenshot when I added port 81 for the password protected interface.
The IP address of the Spark is displayed on the LCD. The IP address above is the IP address on the docker network. You can ignore it.
Exit with CTRL-C the first time. It should now be running in DFU mode. Then run it again. When you have set up wifi, the Spark will download a new bootloader from the Particle server.
Hi Elco,
I tried to run the entire script and got the message:
“dfu-util: Cannot open DFU device 2b04:d006” I am sure you know why.
The 2nd time the script was executed the final screen message was
Hi Elco,
There is nothing logged since 22mar2018 as shown below, which is all that’s found under Maintenance/View Logs tab. Looking in our community I can see others have had the same issue, but obviously, no one after you introduced the Docker technology. Can it be something with the folder structure on my Raspberry Pi? When I press the key “Start Script” nothing is logged in the “log window dialog”. Does this say something? Maybe that the system is not running at all. Everything looks fine on Brewpi Spark showing IP address 192.168.1.172.
Hope this gives you a hint!
BR Ken
Mar 22 2018 20:43:54 Notification: Script started for beer ‘My First BrewPi Run’
Mar 22 2018 20:43:54 Connecting to controller…
Mar 22 2018 20:43:54 Background thread for serial started
Mar 22 2018 20:44:04 Warning: Cannot receive version number from controller. Check your port setting in the Maintenance Panel or in settings/config.cfg.
Mar 22 2018 20:55:05 stopScript message received on socket. Stopping script and writing dontrunfile to prevent automatic restart
Mar 22 2018 20:55:05 Background thread for serial stopped
Hej Elco,
I have just tried the USB connection (serial port), but I cannot start script either through that interface. There is nothing communicated to the log windows (stderr:), which is really strange, since I stil got the error shown below, when trying to refresh devicelist?
Error while receiving device configuration: Couldn’t write to socket: [111] Connection refused Is the script running?
This was caused by a bug that I just fixed.
If you update the container (in portainer click the recreate container button and pull the latest image), then it will start working again.
Hi Elco,
Sounds good you found a bug and fixed it
I am not sure how to recreate containers and pull the image, is it with this script “docker-compose up --build”?
BR Ken
Hi Elco
I found the recreate button, but running the recreation gives a failure “Unable to remove container”, then the contianer list is empty.Shall I reload the containers by running the portainer docker image?
BR Ken
Hi Elco,
I have created the portainer again with the docker script, but the script will still not start. Do you think I still have the version with the bug?.
If I restart http://raspberrypi.local/ the web interface does not remember the IP address. Does this give you a hint?
BR Ken
