Fahreinheit temps on the Spark display got fixed.
But now the mock temp sensors are hosed.
When I type a temperature, it multiplies that value I enter by 9/5 and adds 32.
In other words, I have to enter temps in Celsius to get the temp I want.
Updating again and flashing from the command line resulted in no change.
Adding new blocks and deleting them works.
Changing any setting (even turning an actuator on/off gets the same error.
and the Spark in a boot loop. unplugging USB (sole power and comm source) and reconnecting doesn’t solve the Spark condition.
The Spark boots, progress bar goes all the way to end, it says “Ready” then led turns red with a series of flashes that is too complex for me to count this early, followed by 7 slow flashes.
Does that light show twice, then reboots.
INFO Flashing Spark…
Triggering dfu on port /dev/ttyACM0 [Error: Error: No such file or directory, cannot open /dev/ttyACM0]
Flashing P1…
Flashing System 1 file…
Flash success!
Flashing System 2 file…
Flash success!
Flashing Firmware file…
Flash success!
This brought the Spark back online.
When I opened up the interface, I got a notice stating there firmware update available; snoozed that.
Setting values is good to go now.
500 response errors are gone as well!
