Yes, put the fridge sensor in the beer and run in fridge constant mode.
Reduce the PWM period to 180 and the minimum on time to 30s.
We dont support running a profile with fridge constant mode.
That’s hugely disappointing. Profiles are the number one reason I started this project and bought all this stuff.
Realistically - what’s it going to make these improvements possible? Multi-chamber support requires a new web services API. I would be happy to help there with some clear direction. And this issue… where can I help?
I have invited you on Slack.
Using beer profile with glycol might be possible with a few hacks, but I would need to know more details about your system.
We have already started work on the new API, so having to run in fridge constant mode is a temporary issue.
Any timing on this? New fermenter is due soon and it will have a glycol cooling too.
And would be nice to run thd fermentation whike next next batch is being mashed.
could you (both?) also explain your setup?
i am also building a glycol setup so at this point I have
fridge with glycol reservoir
ss brewtech 14 gallon chronical
heating pad
i need to have brewpi control my pump to pump glycol when needed, and enable the heater when needed.
I just had a new idea:
By implementing that, BrewPi can control the glycol with just a beer sensor and no fridge sensor. It is a quick temporary solution until we have independent and configurable control loops.
Ok so my setup consists of the following:
Window AC unit with coils submerged in Glycol holding tank
Cooler cut and converted to holding tank
ITC-1000 used to control Glycol temps
Three submersible pumps (2 recirculate Glycol in tank, 1 pumps Glycol to fermenter)
Old Arduino BrewPi running the cooling pump/recirc pumps
I live in central Texas so no need for heat, mother nature provides ample. I put the beer in the thermo and the fridge attached to the side of the conical and am able to run pretty well, but even this isn’t perfect.
Cheers,
-Stephen
I love this idea! I’m glad I’ve been slacking this week on my plans. Tomorrow I was going to give into letting brewpi control the glycol temp even though that meant only one fermenter!
I even managed to get two brewpis controlled by one raspberry pi using the auto install scripts and used symbolic links to share the ferment data so I can see what has been brewed on either brew pi on either webpage.
I’m getting excited! So thankful for all the work you guys have been doing!
but do you want to have BrewPi control the glycol temp or the pump for the glycol?
I think of this thing controller the pump for the glycol, and have the glycol temp as cold as possible…
looking for input
Depending on how your chiller is going to chill the vessel you will find you have to adjust things a decent bit on the cold side. I have two 1/2bbl SSBrewtech conicals with the FTSs coils in them and we found that if I super chilled my glycol I would bounce all over the place (overshoot was really bad). I had to dial back the glycol temp greatly to get things in line because the coils chilled almost too well.
Cheers,
-Stephen
hmm… i have 2 14 gallon brewmaster editions and plan to run glycol at -20 celsius through them… would that be too cold?
Depending on what you are trying to ferment that will probably be way too cold.
i’m thinking of having brewpi control the pump, then only let the glycol circulate when i need it to cool down.
I run my glycol at 40F most of the time. thats more than sufficient for fermentation temps. Just kegged a beer today that spent last week at 50F waiting on me to get to it, and had no problems maintaining the temp. Of course 40F also because I just haven’t gotten around to actually adding glycol to the glycol mixture and I get freezing on the coils with plain water at around a 36F set point.
I’ll have a test setup for glycol soon
New conical just arrived.
Still have to convert my glass door freezer into a fridge + kegerator + glycol chiller
Ordered 2 perlick 650ss taps and secondary CO2 regulators.
I’m going to use a steel jerrycan as glycol reservoir.
1BBL Brewmaster edition , nice;)
Nope, that’s the 14G.
Ok. Was confused because only the 1BBL version comes with that perforated plate between the legs. Forgot it can be ordered extra;)
Are you planning on doing the coils on the side?
Yeah, the Brew Master Edition comes with the coils. I’ve got the same one, but didn’t go all out and get the shelf, leg extensions AND casters. WOWZA! That’s nice.
