This happens because you flashed a new image. Your own computer sees that the fingerprint for your Pi changed, and freaks out.
To fix this, remove the stored fingerprint by running this command on your windows pc:
ssh-keygen -R {PI_ADDRESS}
The host should be the name you use to ssh. Going from the earlier error, I think thatâs either raspberrypi or raspberrypi.local (or both)
When I flash for the Spark, I get the message
Only if the LED is blinking blue after the firmware is flashed , run:
I usually see the blue light breathing and not blinking. Do you literally mean blinking but not breathing?
Yes. Blinking and breathing are two different things. When itâs blinking, the screen will also be completely black.
Yepp and thanks for all your good help.
After some while some widgets fall out of the screen. A screen refresh brings them back.
That bug has a fix waiting for release. Most likely tuesday or wednesday.
Hi Bob,
I am going to start again from scratch - Is there a way I can save all the blocks on the spark into a txt file or something - as a reference for when I blow away all the block?
Cheers
Admin page â spark service â backups. You can download the latest there.
If the UI is not cooperating, you can also get the files at the brewblox/spark/backup/{service}/ directory. Theyâre json files with the date in the name.
Hi Bob,
I can see how to export a layout, but I am not sure how to import one, please can you advise?
Many thanks
Open the Builder editor, and click on the three dots in the top right corner. Under âBuilder actionsâ, thereâs âImport Layoutâ.
Weâre aware that itâs somewhat hidden. A rework of import/export UX is on the todo list.
Thanks bob, that worked fine
Hi again
After the 2023/05/30 update my actions widget has some âproblemsâ. When I select disable or one of the profiles, the field goes green. When I select one of the constant temp. fields there is no green. I think it works ok.
The action is green when applying it would not change anything. When you hover over the constant temp action, what does it say it would change?
The green is pretty vague, but it looks like it thinks 68.00 C != 68.00 C?
This setting comes up with 20°C as preset and I reset it to 68°C.
I tested a bit more. Const. MT has a stored setting 20°C. When I donât change it, it comes out green. When I change it (= another setting than the stored one), it doesnât go green. So I set my stored setting to be what I want and it turns green and works. However, I canât say I understand whatâs happening.
