RPi3 is connected on ethernet cable and wifi is not configured. After some number of hours I am unable to ssh or ping it. After a power cycle, I can ssh and check the logs in /var/log/messages (see bottom of post). These messages have been happening, about every 8 minutes the entire time since startup and they continued after network connectivity was lost. (I had a live ssh session tailing the logs and network was lost at 2am. I power cycled at 9am in the morning and logs below show it still continuing at 4am.)
Additionally, during the day, the brewblox web UI reports lost connectivity to the Spark, then connectivity comes back after a minute or two. This happens somewhat regularly, though less frequently than every 8 minutes (this behavior doesn’t appear to line up with the logs below).
(EDIT: IPv6 is disabled. This behavior happened before I installed the 2020/05/04 release, so when I saw the disable IPv6 option (after update) I tried it, but unfortunately that didn’t seem to have an effect.)
Has anyone else seen this behavior or similar logs to these?
More importantly, anyone know what these logs mean?
May 11 04:09:41 fermenator kernel: [50012.090496] br-7cd619fb585b: port 1(veth0de4cca) entered disabled state
May 11 04:09:41 fermenator kernel: [50012.090738] vethee7c288: renamed from eth0
May 11 04:09:41 fermenator kernel: [50012.223511] br-7cd619fb585b: port 1(veth0de4cca) entered disabled state
May 11 04:09:41 fermenator kernel: [50012.233006] device veth0de4cca left promiscuous mode
May 11 04:09:41 fermenator kernel: [50012.233019] br-7cd619fb585b: port 1(veth0de4cca) entered disabled state
May 11 04:09:41 fermenator kernel: [50012.585182] br-7cd619fb585b: port 1(veth2e16985) entered blocking state
May 11 04:09:41 fermenator kernel: [50012.585190] br-7cd619fb585b: port 1(veth2e16985) entered disabled state
May 11 04:09:41 fermenator kernel: [50012.585420] device veth2e16985 entered promiscuous mode
May 11 04:09:41 fermenator kernel: [50012.585676] br-7cd619fb585b: port 1(veth2e16985) entered blocking state
May 11 04:09:41 fermenator kernel: [50012.585683] br-7cd619fb585b: port 1(veth2e16985) entered forwarding state
May 11 04:09:42 fermenator kernel: [50013.866526] br-7cd619fb585b: port 1(veth2e16985) entered disabled state
May 11 04:09:42 fermenator kernel: [50013.867411] eth0: renamed from vethbb70f06
May 11 04:09:43 fermenator kernel: [50013.926965] br-7cd619fb585b: port 1(veth2e16985) entered blocking state
May 11 04:09:43 fermenator kernel: [50013.926977] br-7cd619fb585b: port 1(veth2e16985) entered forwarding state
May 11 04:17:30 fermenator kernel: [50480.916456] br-7cd619fb585b: port 1(veth2e16985) entered disabled state
May 11 04:17:30 fermenator kernel: [50480.917799] vethbb70f06: renamed from eth0
May 11 04:17:30 fermenator kernel: [50481.062730] br-7cd619fb585b: port 1(veth2e16985) entered disabled state
May 11 04:17:30 fermenator kernel: [50481.071771] device veth2e16985 left promiscuous mode
May 11 04:17:30 fermenator kernel: [50481.071783] br-7cd619fb585b: port 1(veth2e16985) entered disabled state
May 11 04:17:30 fermenator kernel: [50481.397773] br-7cd619fb585b: port 1(vetha1a5103) entered blocking state
May 11 04:17:30 fermenator kernel: [50481.397783] br-7cd619fb585b: port 1(vetha1a5103) entered disabled state
May 11 04:17:30 fermenator kernel: [50481.398078] device vetha1a5103 entered promiscuous mode
May 11 04:17:30 fermenator kernel: [50481.398414] br-7cd619fb585b: port 1(vetha1a5103) entered blocking state
May 11 04:17:30 fermenator kernel: [50481.398422] br-7cd619fb585b: port 1(vetha1a5103) entered forwarding state
May 11 04:17:31 fermenator kernel: [50482.667774] br-7cd619fb585b: port 1(vetha1a5103) entered disabled state
May 11 04:17:31 fermenator kernel: [50482.668275] eth0: renamed from veth62910e6
May 11 04:17:31 fermenator kernel: [50482.708391] br-7cd619fb585b: port 1(vetha1a5103) entered blocking state
May 11 04:17:31 fermenator kernel: [50482.708406] br-7cd619fb585b: port 1(vetha1a5103) entered forwarding state
May 11 04:25:19 fermenator kernel: [50949.917279] br-7cd619fb585b: port 1(vetha1a5103) entered disabled state
May 11 04:25:19 fermenator kernel: [50949.920529] veth62910e6: renamed from eth0
May 11 04:25:19 fermenator kernel: [50950.091937] br-7cd619fb585b: port 1(vetha1a5103) entered disabled state
May 11 04:25:19 fermenator kernel: [50950.100453] device vetha1a5103 left promiscuous mode
May 11 04:25:19 fermenator kernel: [50950.100467] br-7cd619fb585b: port 1(vetha1a5103) entered disabled state
May 11 04:25:19 fermenator kernel: [50950.395599] br-7cd619fb585b: port 1(vethbe5aa99) entered blocking state
May 11 04:25:19 fermenator kernel: [50950.395609] br-7cd619fb585b: port 1(vethbe5aa99) entered disabled state
May 11 04:25:19 fermenator kernel: [50950.396182] device vethbe5aa99 entered promiscuous mode
May 11 04:25:19 fermenator kernel: [50950.396818] br-7cd619fb585b: port 1(vethbe5aa99) entered blocking state
May 11 04:25:19 fermenator kernel: [50950.396827] br-7cd619fb585b: port 1(vethbe5aa99) entered forwarding state
May 11 04:25:21 fermenator kernel: [50951.928874] br-7cd619fb585b: port 1(vethbe5aa99) entered disabled state
May 11 04:25:21 fermenator kernel: [50951.929715] eth0: renamed from veth1438fd7
May 11 04:25:21 fermenator kernel: [50951.979381] br-7cd619fb585b: port 1(vethbe5aa99) entered blocking state
May 11 04:25:21 fermenator kernel: [50951.979393] br-7cd619fb585b: port 1(vethbe5aa99) entered forwarding state
