Looks like everything went perfectly (until I tried to bring brewblox up again…?!)
rdh@AirUbuntu:~/brewblox$ sudo vi /etc/apt/sources.list.d/docker.list
rdh@AirUbuntu:~/brewblox$ sudo apt update
Hit:1 Index of /ubuntu impish InRelease
Get:2 Index of /ubuntu impish-updates InRelease [110 kB]
Get:3 Index of linux/ubuntu/ impish InRelease [48.9 kB]
Get:4 Index of /ubuntu impish-security InRelease [110 kB]
Get:5 Index of /ubuntu impish-backports InRelease [101 kB]
Get:6 Index of linux/ubuntu/ impish/stable amd64 Packages [4,136 B]
Get:7 Index of /ubuntu impish-updates/main amd64 DEP-11 Metadata [18.9 kB]
Get:8 Index of /ubuntu impish-updates/universe amd64 DEP-11 Metadata [4,484 B]
Get:9 Index of /ubuntu impish-backports/universe amd64 DEP-11 Metadata [9,088 B]
Get:10 Index of /ubuntu impish-backports/universe DEP-11 64x64 Icons [1,789 B]
Get:11 Index of /ubuntu impish-security/main amd64 Packages [141 kB]
Get:12 Index of /ubuntu impish-security/main i386 Packages [48.8 kB]
Get:13 Index of /ubuntu impish-security/main Translation-en [36.4 kB]
Get:14 Index of /ubuntu impish-security/main amd64 DEP-11 Metadata [6,432 B]
Get:15 Index of /ubuntu impish-security/universe amd64 Packages [49.4 kB]
Get:16 Index of /ubuntu impish-security/universe Translation-en [20.2 kB]
Get:17 Index of /ubuntu impish-security/universe amd64 DEP-11 Metadata [2,308 B]
Fetched 714 kB in 1s (571 kB/s)
Reading package lists… Done
Building dependency tree… Done
4 packages can be upgraded. Run ‘apt list --upgradable’ to see them.
rdh@AirUbuntu:~/brewblox$ sudo apt upgrade -y
Calculating upgrade… Done
The following NEW packages will be installed:
docker-ce-rootless-extras docker-scan-plugin libslirp0 slirp4netns
The following packages will be upgraded:
containerd.io docker-ce docker-ce-cli libexiv2-27
4 upgraded, 4 newly installed, 0 to remove and 0 not upgraded.
1 standard security update
Need to get 98.0 MB of archives.
After this operation, 28.2 MB of additional disk space will be used.
Get:1 Index of /ubuntu impish-updates/main amd64 libslirp0 amd64 4.4.0-1ubuntu0.21.10.1 [58.2 kB]
Get:2 Index of linux/ubuntu/ impish/stable amd64 containerd.io amd64 1.4.12-1 [23.7 MB]
Get:3 Index of /ubuntu impish/universe amd64 slirp4netns amd64 1.0.1-2 [28.2 kB]
Get:4 Index of /ubuntu impish-security/main amd64 libexiv2-27 amd64 0.27.3-3ubuntu4.1 [821 kB]
Get:5 Index of linux/ubuntu/ impish/stable amd64 docker-ce-cli amd64 5:20.10.12~3-0~ubuntu-impish [40.7 MB]
Get:6 Index of linux/ubuntu/ impish/stable amd64 docker-ce amd64 5:20.10.12~3-0~ubuntu-impish [21.2 MB]
Get:7 Index of linux/ubuntu/ impish/stable amd64 docker-ce-rootless-extras amd64 5:20.10.12~3-0~ubuntu-impish [7,920 kB]
Get:8 Index of linux/ubuntu/ impish/stable amd64 docker-scan-plugin amd64 0.12.0~ubuntu-impish [3,517 kB]
Fetched 98.0 MB in 13s (7,780 kB/s)
(Reading database … 186145 files and directories currently installed.)
Preparing to unpack …/0-containerd.io_1.4.12-1_amd64.deb …
Unpacking containerd.io (1.4.12-1) over (1.2.13-2) …
Preparing to unpack …/1-docker-ce-cli_5%3a20.10.12~3-0~ubuntu-impish_amd64.deb …
Unpacking docker-ce-cli (5:20.10.12~3-0~ubuntu-impish) over (5:19.03.12~3-0~ubuntu-focal) …
Preparing to unpack …/2-docker-ce_5%3a20.10.12~3-0~ubuntu-impish_amd64.deb …
Unpacking docker-ce (5:20.10.12~3-0~ubuntu-impish) over (5:19.03.12~3-0~ubuntu-focal) …
Selecting previously unselected package docker-ce-rootless-extras.
Preparing to unpack …/3-docker-ce-rootless-extras_5%3a20.10.12~3-0~ubuntu-impish_amd64.deb …
Unpacking docker-ce-rootless-extras (5:20.10.12~3-0~ubuntu-impish) …
Selecting previously unselected package docker-scan-plugin.
Preparing to unpack …/4-docker-scan-plugin_0.12.0~ubuntu-impish_amd64.deb …
Unpacking docker-scan-plugin (0.12.0~ubuntu-impish) …
Preparing to unpack …/5-libexiv2-27_0.27.3-3ubuntu4.1_amd64.deb …
Unpacking libexiv2-27:amd64 (0.27.3-3ubuntu4.1) over (0.27.3-3ubuntu4) …
Selecting previously unselected package libslirp0:amd64.
Preparing to unpack …/6-libslirp0_4.4.0-1ubuntu0.21.10.1_amd64.deb …
Unpacking libslirp0:amd64 (4.4.0-1ubuntu0.21.10.1) …
Selecting previously unselected package slirp4netns.
Preparing to unpack …/7-slirp4netns_1.0.1-2_amd64.deb …
Unpacking slirp4netns (1.0.1-2) …
Setting up docker-scan-plugin (0.12.0~ubuntu-impish) …
Setting up libexiv2-27:amd64 (0.27.3-3ubuntu4.1) …
Setting up containerd.io (1.4.12-1) …
Setting up docker-ce-cli (5:20.10.12~3-0~ubuntu-impish) …
Setting up libslirp0:amd64 (4.4.0-1ubuntu0.21.10.1) …
Setting up docker-ce-rootless-extras (5:20.10.12~3-0~ubuntu-impish) …
Setting up slirp4netns (1.0.1-2) …
Setting up docker-ce (5:20.10.12~3-0~ubuntu-impish) …
Processing triggers for man-db (2.9.4-2) …
Processing triggers for libc-bin (2.34-0ubuntu3) …
rdh@AirUbuntu:~/brewblox$ docker version
Client: Docker Engine - Community
Version: 20.10.12
API version: 1.41
Go version: go1.16.12
Git commit: e91ed57
Built: Mon Dec 13 11:45:33 2021
OS/Arch: linux/amd64
Context: default
Experimental: true
Server: Docker Engine - Community
Engine:
Version: 20.10.12
API version: 1.41 (minimum version 1.12)
Git commit: 459d0df
Built: Mon Dec 13 11:43:41 2021
Experimental: false
containerd:
Version: 1.4.12
GitCommit: 7b11cfaabd73bb80907dd23182b9347b4245eb5d
runc:
Version: 1.0.2
GitCommit: v1.0.2-0-g52b36a2
docker-init:
Version: 0.19.0
GitCommit: de40ad0
rdh@AirUbuntu:~/brewblox$ brewblox-ctl up
Starting brewblox_victoria_1 …
Starting brewblox_history_1 … error
Starting brewblox_spark-one_1 …
Starting brewblox_victoria_1 … error
Starting brewblox_ui_1 …
Starting brewblox_traefik_1 …
Starting brewblox_redis_1 …
ERROR: for brewblox_history_1 Cannot start service history: OCI runtime create failed: container wiStarting brewblox_eventbus_1 … error
Starting brewblox_spark-one_1 … error
with id exists: 6020c0e4f4b8109c1c4bfd8f9ba224c724660839fe4313d8a53c5359d52164ef: unknown
ERROR: for brewblox_eventbus_1 Cannot start service eventbus: OCI runtime create failed: container with id exists: 8530dbcb9d1d8cf7d3cfe72a42ae9d8ba4bd1dc9b3307cebf32575a698ebdf86: unknown
Starting brewblox_ui_1 … error
ERROR: for brewblox_spark-one_1 Cannot start service spark-one: OCI runtime create failed: container with id exists: 51b18b978a83ef89f0a2c6ca971857a24b698fc0d1f9287c8a543546a0ae1af8: unknown
ERROR: for brewblox_ui_1 Cannot start service ui: OCI runtime create failed: container with id exisStarting brewblox_redis_1 … error
Starting brewblox_traefik_1 … error
d exists: 1f6cd0d066cde76db7a119fdcea34bb0a1bcfadca7a200e26de01ddddc174529: unknown
ERROR: for brewblox_traefik_1 Cannot start service traefik: OCI runtime create failed: container with id exists: 4c380090ed5b8ce3e76871f2dbffc180c244abac2c77e0031cf6118fcd06878f: unknown
ERROR: for history Cannot start service history: OCI runtime create failed: container with id exists: a179a7fd5bf86a55c26271fca5c5b2acf5337980409eeb7eae03e41fb7de01fa: unknown
ERROR: for victoria Cannot start service victoria: OCI runtime create failed: container with id exists: 6020c0e4f4b8109c1c4bfd8f9ba224c724660839fe4313d8a53c5359d52164ef: unknown
ERROR: for eventbus Cannot start service eventbus: OCI runtime create failed: container with id exists: 8530dbcb9d1d8cf7d3cfe72a42ae9d8ba4bd1dc9b3307cebf32575a698ebdf86: unknown
ERROR: for spark-one Cannot start service spark-one: OCI runtime create failed: container with id exists: 51b18b978a83ef89f0a2c6ca971857a24b698fc0d1f9287c8a543546a0ae1af8: unknown
ERROR: for ui Cannot start service ui: OCI runtime create failed: container with id exists: af133295d0295f3be62c6d7dd4c6dd4af6b7f2076c9732baabc0c323658c7dfa: unknown
ERROR: for redis Cannot start service redis: OCI runtime create failed: container with id exists: 1f6cd0d066cde76db7a119fdcea34bb0a1bcfadca7a200e26de01ddddc174529: unknown
ERROR: for traefik Cannot start service traefik: OCI runtime create failed: container with id exists: 4c380090ed5b8ce3e76871f2dbffc180c244abac2c77e0031cf6118fcd06878f: unknown
Command 'docker-compose up -d ’ returned non-zero exit status 1.
