Okay, I ran the command, then the BrewPi didn’t respond anymore, so I went ahead and ran the update and got the following:
pi@raspberrypi ~ $ sudo python ~/brewpi-tools/updater.py
#### Welcome to the BrewPi Updater! ####
Quit message sent to BrewPi instance with pid 2396!
You are on branch master
The latest commit in /home/brewpi is 015e5c7040672af9e0dc3045ac1b681036c372d6 on Wed, 22 Apr 2015 05:01:36
The latest commit on origin/master is 015e5c7040672af9e0dc3045ac1b681036c372d6 on Wed, 22 Apr 2015 05:01:36
The latest commit in /var/www is d44c03e786d0bde0dc43f86a8bd655659f3f3d2b on Wed, 11 Mar 2015 17:59:39
The latest commit on origin/master is d44c03e786d0bde0dc43f86a8bd655659f3f3d2b on Wed, 11 Mar 2015 17:59:39
The update script can automatically check your controller firmware version and program it with the latest release on GitHub, would you like to do this now? [Y/n]:
Stopping any running instances of BrewPi to check/update controller...
Checking current firmware version...
Current firmware version on controller: 0.2.7
Checking GitHub for latest release...
Latest version on GitHub: 0.2.10
Version on GitHub is newer than your current version, downloading new version...
downloading https://github.com/BrewPi/firmware/releases/download/0.2.10/brewpi-spark-core-revc-0_2_10.bin
Latest firmware downloaded to /home/brewpi/utils/downloads/0.2.10/brewpi-spark-core-revc-0_2_10.bin
**** Spark Core Program script started ****
Checking current version: Found BrewPi v0.2.7 build 0, running on a Spark Core with a Rev-C shield on port /dev/ttyACM1
Requesting old settings from Spark Core...
Saved old settings to file settings-Apr-30-2015-18-50-55.json
Waiting for the binary file to be sent ... (press 'a' to abort)
sent packet nr 0
sent packet nr 1
sent packet nr 2
sent packet nr 3
sent packet nr 4
sent packet nr 5
sent packet nr 6
sent packet nr 7
sent packet nr 8
sent packet nr 9
sent packet nr 10
sent packet nr 11
sent packet nr 12
sent packet nr 13
sent packet nr 14
sent packet nr 15
sent packet nr 16
sent packet nr 17
sent packet nr 18
sent packet nr 19
sent packet nr 20
sent packet nr 21
sent packet nr 22
sent packet nr 23
sent packet nr 24
sent packet nr 25
sent packet nr 26
sent packet nr 27
sent packet nr 28
sent packet nr 29
sent packet nr 30
sent packet nr 31
sent packet nr 32
sent packet nr 33
sent packet nr 34
sent packet nr 35
sent packet nr 36
sent packet nr 37
sent packet nr 38
sent packet nr 39
sent packet nr 40
sent packet nr 41
sent packet nr 42
sent packet nr 43
sent packet nr 44
sent packet nr 45
sent packet nr 46
sent packet nr 47
sent packet nr 48
sent packet nr 49
sent packet nr 50
sent packet nr 51
sent packet nr 52
sent packet nr 53
sent packet nr 54
sent packet nr 55
sent packet nr 56
sent packet nr 57
sent packet nr 58
sent packet nr 59
sent packet nr 60
sent packet nr 61
sent packet nr 62
sent packet nr 63
sent packet nr 64
sent packet nr 65
sent packet nr 66
sent packet nr 67
sent packet nr 68
sent packet nr 69
sent packet nr 70
sent packet nr 71
sent packet nr 72
sent packet nr 73
sent packet nr 74
sent packet nr 75
sent packet nr 76
sent packet nr 77
sent packet nr 78
sent packet nr 79
sent packet nr 80
sent packet nr 81
sent packet nr 82
sent packet nr 83
sent packet nr 84
sent packet nr 85
sent packet nr 86
sent packet nr 87
sent packet nr 88
sent packet nr 89
sent packet nr 90
sent packet nr 91
sent packet nr 92
sent packet nr 93
sent packet nr 94
sent packet nr 95
sent packet nr 96
sent packet nr 97
sent packet nr 98
sent packet nr 99
sent packet nr 100
sent packet nr 101
sent packet nr 102
sent packet nr 103
sent packet nr 104
sent packet nr 105
sent packet nr 0
File flashed successfully
Waiting for device to reset.
At this point I walked away, had dinner, did some laundry, came back and it was still at the same point, so I disconnected the BrewPi and plugged it back in which cased:
File "/home/brewpi/utils/updateFirmware.py", line 144, in <module>
result = updateFromGitHub(userInput)
File "/home/brewpi/utils/updateFirmware.py", line 124, in updateFromGitHub
{'settings': restoreSettings, 'devices': restoreDevices})
File "/home/brewpi/utils/../programController.py", line 160, in programController
return programmer.program(hexFile, restoreWhat)
File "/home/brewpi/utils/../programController.py", line 225, in program
self.fetch_new_version()
File "/home/brewpi/utils/../programController.py", line 308, in fetch_new_version
self.versionNew = self.fetch_version("Checking new version: ")
File "/home/brewpi/utils/../programController.py", line 293, in fetch_version
version = brewpiVersion.getVersionFromSerial(self.ser)
File "/home/brewpi/utils/../brewpiVersion.py", line 60, in getVersionFromSerial
ser.setTimeout(oldTimeOut) # restore previous serial timeout value
File "/usr/local/lib/python2.7/dist-packages/serial/serialutil.py", line 402, in setTimeout
if self._isOpen: self._reconfigurePort()
File "/usr/local/lib/python2.7/dist-packages/serial/serialposix.py", line 325, in _reconfigurePort
raise SerialException("Could not configure port: %s" % msg)
serial.serialutil.SerialException: Could not configure port: (5, 'Input/output error')
*** Done updating BrewPi! ***
After trying BrewPi web interface and it saying the firmware wasn’t updated, I tried again:
Round 2:
It locks up at this point.
